Ok I have a Pro-comp 6 inch lift, I also am going to put
the ford torsion keys up front to raise the front end about
2 inches, Now what should be done about the rear?
I called up four-wheel parts and they told me to call
Superlift about the rear end. Because this is a custom
lift application. Any ideas?? thanks
Id rather not go into a bigger block... axle wrap
They said add-a-leaf, would make the ride rougher and it
make everything more of a hassle..... Havnt thought about
shackles tho.
Doesnt superlift use a 6 inch block with there lift??
Usually they don;t make rear blocks bigger than 4 inches do they??? After the blocks they use add-a-leaves....anyway...if you want more lift, why not just get a bigger lift kit??? Go up to 8 or ten inches....other than that all I could think of is a body lift
I know Skyjacker makes an over the counter set of leaf springs for there 6" lift. If was doing it, I would install a set of those springs and then fine tune it with a block. At the worst, you'l probably be replacing the factory block with a 3.5".
Kenny
