- 0
6l80e transmission fluid pressure sensor/ switch circuit low
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 12 Members, 3 Anonymous, 2,073 Guests (See full list)
Question
apollo18
hey guys! i have a 2007 truck with a 6l80e transmission. The truck has a 1-2 hard shift. and the 2-3 is slightly wonky.. 3-4, 4-5, and 5-6 are PERFECTLY SMOOTH. The tranny has stock tune on it so does the engine. Fluid and Filter was just swapped out with pan drop about 5 months ago. This problem has been going on for like 1-2 years and i never bothered to fix it since I dont drive the truck that much. This is also the 2nd transmission. It has about 200k km's on it, and was brand new from GM. Had it installed in 2011/2011. Two weeks ago, I had a mechanic use a tech 2 to check it out. He reset the trans adapts and the problem went away for about 10 days. It shifted perfectly smooth every single shift. But now the problem is back. the 1-2 is hard, and the 2-3 is slightly hard. He wrote down the codes and was supposed to get back to me about how he was gonna fix it, but he never did and stopped replying now. The truck now went back to how it used to be. A diff mechanic I found used a MacTools Mac TaskPlus and got 4 TCM codes. The codes are:
P0872 Transmission Fluid Pressure Sensor / Switch C Circuit Low
P0877 Transmission Fluid Pressure Sensor / Switch D Circuit Low
P0842 Transmission Fluid Pressure Sensor / Switch A Circuit Low
P0989 Transmission Fluid Pressure Sensor / Switch E Circuit Low
these are the 4 codes. Im guessing this sensor/switch is bad and needs to be replaced?
anyone have any help/info?
thanks alot!!
7 answers to this question
