Play In Front Differential
Found a replacement front differential at a junk yard, recently. Cracked the inner axle housing (passenger side) on the 2008, so it had to be repaired, or replaced.
Comparing the two, noticed the replacement has around 3 degrees of lash, when turning the yoke by hand. Felt solid, otherwise. Original had virtually no perceptible rotational play.
Even if it's OK, will the replacement seem "clunkier?"
Thanks for your help!
