Tail Gate Assist Info
GM offers a tail gate assist that helps in lowering/raising truck tailgates for their newer trucks. Does anyone know of a supplier for kits to retrofit the tailgate of my truck. My truck is an 07 GMC Sierra Classic W/T. A search for the kit has been unproductive.
You can buy all of the parts through GM, I tried this on my 08. There are quite a few parts that you have to buy, they are not cheap, and there is one piece that holds the rod that goes the length of the tail gate that I could never figure out. The problem with that body style compared to the new generation is that there is no access panel to get to the guts of the tailgate. I would go with the Dee Zee as the above post suggests, have used on prior trucks, including the 08, and they work pretty good.
  • 5 months later...
I installed the Dee Zee 43100 on my 16, RCSB and it works Great for aftermarket gas tube and easy to mount..
Very handy...
Cheers----K
When you put the blind bolt in, was there something it screwed into? The one I got seemed smaller than the hole and didn’t do to anything to secure it.
The Dee Zee kit has threaded insert unit that needs to be installed in the gate - Factory Hole.
Once completed,, bracket support bolt can be screwed in...
Hope this helps...
Cheers----K
