How to wire up Leer 100XQ on 2015 Silverado
Ok, I am a new member and need some help. I have a 2015 Silverado LTZ Crew Midnight Edition and I just bought a Leer 100XQ. I was surprised to find out that the dealer for Leer did not hook up the electrical stuff which includes the lights, third brake light, and auto lock. I have looked at the instructions they provided and they are not very good. Does anyone have any detailed instructions or a link to a video of how to install this stuff? I hate to pay another few hundred bucks to get it installed when the dang topper was $2500 by itself. So basically I am looking for where on my 2015 Silverado to hook up the wires for the light, the hook up for the wires for the third brake light, and where to hook up the auto lock which is supposed to unlock when you unlock the door of the truck. Any help would be greatly appreciated. Thanks.
Check out these links. I'm about to do this for my 2017 and a ARE Z series cap. You're looking for the X63A Rear Junction Block
https://www.gmupfitter.com/files/media/photo/581/UI%20Bulletin_122.pdf
https://www.gmupfitter.com/files/media/photo/510/UI%20Bulletin_113.pdf
Also, you might have a bit better luck posting in the year-specific forum if you need more info. Mostly because this varies a bit with the model and trim, in my understanding.
Btw, if you have any info into hooking up the e-lock, let me know [emoji1360]
Edited by corncob
I hate to say this,, Take it back to dealer for light / lock wiring..
You not only have warranty but they did not complete install..
Have 100XQ and local dealer did Great job and testing lights befor I left his shop...
Save your time and hassle...
Cheers---K
Under the fuse panel under the hood on the right side of the engine compartment there is a schematic of what fuses are where. If you look at Fuse #38 it is the CHMSL wire. If you purchase a micro 2 add a fuse line you can tap into this fuse and just run the line to the back of the truck. This was the easiest way I could figure out how to run this wire since nobody can show me a picture of where the X63A Junction Block is on my 2015 Silverado. Although what Corncob posted are the best I have seen to date.
Edited by Bigsho69
I connected the wire to the add a fuse and ran it through the firewall at the main wiring harness grommet. I cut a small slit in the nipple that sticks out of the front of the grommet and pushed a thin rod through the firewall with the wire taped to it with electrical tape. This took some trial and error but I finally got it through.
With the wire box cover removed I was able to get the blue wire to run just left of the box (marked with yellow arrows). I then ran this under the carpet and out through the emergency brake grommet in the floor. Then I ran the wire back to the back of the truck and up through the left brake light.
This was the factory wire harness from LEER that is inside the topper. The directions they gave were not very good. I had to experiment with the pin connectors and had to order new crimp pins because I had the wires crossed up. Green wire from the power lock went between the red and red/white wires and the blue wire went right next to the green. (don't confuse my blue wire I used for my CHMSL line from the fuse box with this blue wire from the auto lock wires).
This is the wire harness plugged in on the inside of the topper. You can see the blue and green wire that runs from the inside of the cab (connected to the lock and unlock wires). You can search the Pop and Lock directions and find very good directions for hooking this up. Make not that the wires to hook up under the door sill are a tan/yellow thicker wire and gray/green. Both of these wires are slightly thicker than the rest. These directions are pretty much the same for hooking up the wiring for the auto lock on the LEER topper.
http://www.gm-trucks.com/forums/topic/156468-2014-power-tailgate-lock-installed/
Here is the third brake light working FINALLY!!!! This was not an easy job to figure out with no help. Hopefully if someone gets stuck they can use what I did to help them get it installed. I wired a hot wire from under the dash to power the interior light of the topper, grounded the ground wire in the left taillight, then ran the wires for the auto lock mechanism. Everything works and I am pleased with being able to do it myself.
  • 1 year later...
  • 6 months later...
On 9/16/2018 at 4:51 AM, mtushmoo said:
 Does this replace the unused cap/plug down by the spare tire on a 2016 Sierra w/ in-bed under-rail lighting?
It uses the connector that the bed lights are currently using.  It provides a ground wire, a third brake light wire, and the cargo light feed that works off the dash switch with the same functionality as the factory bed lights.
If you have the bed lights and want to add a third brake light you can track down the terminal and seal and add the wire to the connector body you have, or get this connector and splice the bed lights on to it.
    247.7k
    2.6m
    folifresh
    folifresh
  • Who's Online   2 Members, 0 Anonymous, 1,183 Guests (See full list)
