Front end sag
So I have a 15' denali with 6.2l. I have been noticing more and more when I look at it the front end really comes down
I want to do a 2.5 leveling kit but feel I may need to do more in the front to "level" it out.
Add a couple inches to the front end and that should be good, unless you just want to get a straight up lift kit. I added the bilstein struts up front to my 14 on the 1.85" lift setting and I constantly debate on adding a leaf to get some of the rake back because the front is so high.
2014 Silverado Z71
2.5' will over level you and you will be nose high. 2 inches should be perfect.
are you saying only 2.5" front?
because i want to bring the whole truck up 2.5" plus level the front... so i am thinking of doing a 1.5" rear and 2.5" front. that way i bring the front up an inch to maybe make it closer to "level" to the rear
You should read some of the other threads on leveling and lifts on this forum. There is a lot of reading, but spending the time now can save you a lot of money. If you don't want to take the time then I highly recommend you take the advice offered of getting a 2" level. (1.5 is even better, imo). Your truck will appear level, maintain its current ride qualities and is not expensive. FYI, You will need an alignment following any modification to the suspension.
No. I am saying leave the rear stock and go 2 inches in the front. You wanted per your original post to level it out.
Quoting your original post:
That's how trucks sit. A 2" level in the front will have it looking good. 2.5 and up start to put a lot of stress on the ball joints.
Start to? A 2 inch does the same thing (add stress) just a little less than a 2.5. Anything over stock adds stress, the higher you go the more stress is added. A 1.5 adds stress, not as much as a 2 or 2.5 but it adds stress none the less...
Tyler
Tyler
Any level will add some stress, but it seems like the guys who did the 2.5 over the 2 kill ball joints much faster. You can read it in the leveling kit thread. I'm not saying it won't add extra stress, just not as much.
I just did 1.5" spacers under my front shocks yesterday (went with Motofab), very easy to do and I now only have a 1" rake instead of almost a 3" rake prior. Other than the nose riding higher I haven't really noticed any difference in the way the truck drives....Getting my alignment in a few day's.
Or we could load you up like a job site truck and you'll have 750Lbs in the bed constantly. Then hook up a trailer to it. That'll level you right on out.... Being seriously, the 4WD trucks have a better stance than the 2wd trucks. the 2 wheelers look nose low.
so then to add another factor to this boys... if i wanted to do a 2" overall lift while keeping the front level with the rear with 2" lift.. i am looking at a 4" front lift?
now with the denali i feel that maybe i may not want to adjust my shocks and such because then i will loose ride quality. i feel like i put myself in a crappy situation to really lift this vehicle while keeping the factory ride quality.
i want to be able to do 35' with 22's is my goal. i also want the truck to sit even
to do 35's i have seen guys going with the 2.5" lift and rubs a little. so will 35's fit with 1" rear lift?
No. 4 in the front and two out back. Not gonna happen. You could do 2in in the front and then a 2" body lift, but 35" you might as well do a Magnetic Ride Control compliant 6" lift and be done with it. I've seen the HD trucks fit 35" with a level. but the most on a leveled 1/2 ton I've seen fit good was a 33"
Edited by 15HDriver
Sigh. I really wanted to stay away from big lift. But go big or go home I guess
Could you leave the front alone - and shackle the back to level it and not lose ride quality on mag ride?
