GMT900 Corsa Sport Series Cat Back Exhaust 14259 CUSTOM
AllBlkdOut07
Corsa Part number #14259 came off my '07 New Body Style 5.3 Silverado with 143.5 wheelbase, Extended Cab w/ Standard Bed, it may fit others.
This is full 304 S/S but has been Jet Hot Coated in matte black and can easily be touched up with flat black BBQ paint if you want it to look perfect prior to installing it.
It also has been customized with a large 5" angled, double wall tip and dumped over the rear axle for a super clean look.
Truck was barely driven in 7+ years, so there are very few miles on the exhaust.
Guess it can be stripped and polished if you really wanted.
You know these aren't cheap exhausts, it's Jet Hot coated, custom dumped and has the big tip.
Installs easily, just bolt it up and go.
$750 Local pick up NJ (no shipping)
Shots taken today, a little dirty under there
Older pics for more angles when it was first jet hot sprayed. If you spray it yourself, it can look like new again.
Sandblasted then BBQ spray painted before I had it Jet Hot coated and dumped over the axle
