GMT900 07-13 Rancho 4.5" Suspension Lift Skid Plate CUSTOM
AllBlkdOut07
Custom designed s/s waterjet skidplate + Rancho skidplate frame
This is a one of its kind skidplate that has I illustrated and waterjet out of stainless steel plate that has been mirror polished on the front and silver powdercoated on the back. I also have the original Rancho skidplate that is powdercoated in textured black if you prefer that one instead.
It will fit the 4" Rancho suspension lift kit RS6583, part number for the skidplate frame is RS8716. This is a discontinued item by Rancho so it is now obsolete, they no longer make them.
Framing itself has been powdercoated in silver metallic.
It will come with all necessary hardware.
I prefer local pick up (NJ) but will ship, just send me your zip code.
$400 [+ shipping]
That sucks. It looks pretty sick. Could you send a measurement, from crossmember mounting holes? This way I can get a idea, if it will work. Thanks
You could absolutely make this fit a few different ways.
The two top tabs on the skidplate frame bolt up to your existing frame rail, using existing holes there, so those aren't a problem.
The back two mounting points/holes could easily be drilled out of your zone cross member, or you could have someone fabricate small brackets so it bolts up to the zone cross member if the angle wasn't right, but I would assume that might not even be an issue. If you like it, you could get it to fit.
The two holes at the bottom that bolt up to the cross member are exactly 22" apart on center.
The rear mounting tab to the front mounting tab on center is also 22".
$400 [+ shipping]
Thanks. I will measure once off of work today. Get back to you. Thanks again.
  • 3 weeks later...
