What Type of Locks Are Recommend
Not sure what you have there but on my enclosed tool trailer (Bumper htich) I just use a standard yellow reese coupler lock unless I have to park and leave it overnight in an area that looks a little sketchy. If I get concerned i will take a medium chain and wrap it around the tongue and coupler about 6 to 8 times and use a high quality master lock to lock the chain together. Makes a real tough barrier to get through and would take them to much time so they move on for easier prey.
I would recommend you check out the Fort Knox locking systems. We have one for our gooseneck horse trailer and it is very strong and secure. They also make locks for bumper pull and fifth wheel trailers.
Watch their security test videos of other locks and you'll see how simply most hitch locks can be defeated. (Be sure to scroll down on the Video page to see all the videos.)
https://www.ftknoxlocks.com/
Keep in mind that a lot of couplers are "adjustable", and a simple lock through the latch is pointless because you can simply back a nut off then retighten once over the ball...not only do they steal your trailer, but they steal your lock too.
I have a Reese and a Masterlock brand ball couple lock. You need to know your coupler and/or test fit before relying on one to protect your trailer. I have two because they each work on a particular trailer, and won't work on the other trailer.
If you have a forged hammer blow coupler, good luck as I have not found a lock for those yet.
I use a Master Discus padlock on the entry door and the rear ramp.
And a Reese lock for the coupler.
4758b9f3-d7a2-42bc-befb-c56cdd123950_1.9
The master number 40 is easy to pick. It uses the same 4 pin core as the Master number 1, 3, and 5. I can get into the 5 in under 12 seconds. I haven't tried picking the Reese lock yet. But I will not put a Master on anything anymore now that I know how easy they are to pick
If you value the contents and they are not insured against theft, I would go with the ABUS 37RK/80 Granit. It isn't cheap, but it also is secure. If a disc lock is a must have, the ABUS 20/70 Diskus for about $30 would be my pick.
Holy [emoji90] The abus lock is $105
Yea, but the master is so easy to get in. Seriously a bobby pin, a small screwdriver, and a wiggle. If your stuff is valuable, spend the money on a good lock.
I agree with that statement I have had issues with master locks over the years as well. I like the lock disc a lot better than the other one but that's me and I'm sure it will provide the same security or deterrent
I pleat Lee agree with that statement I have had issues with master locks over the years as well. I like the lock disc a lot better than the other one but that's me and I'm sure it will provide the same security or deterrent
I did highlight the best one, but I did give a cheaper alternative. I would not hesitate to get the Abus Diskus at the sub $40 price
A shielded and boride lock...I'd like to see that, I'm not talking about POS from Walmart; but an industrial/commercial lock. I'd like to see how easy that can be done, because I use them.
Sent from my SM-T350 using Tapatalk
A standard pad lock including combo can be shimmed. The disc and the ones where the hasp is less exposed really can't be. Or if they can, it is way above my skill level. I know those really experienced can crack those by feeling the detents.
But do you want to deal with a combo every time you need in your trailer?
