2017 HD Hood Conversion
Ok here are the rest of the parts you will need and the part numbers.
The springs : 84171187 and 184171188 the also come in black and are a bit smaller, same part number, either ones you get will work
The duct retainer clips and screws
Edited by TheGovernment
Will this fit on a '15 Sierra? I have the carbon fiber edition; would I be able to install the graphic on this hood?
My factory hood suffered hail damage last year and it's a lot so this would actually serve a purpose.
Will the carbon fiber graphic fit on it? Is there even a way to order the graphic separately? It's the main feature of why I bought my Sierra.
You'd have to go to a wrap shop and get them to custom make you one.
Yes, your local parts dept can order them using your vin
Edited by CBRAGA
Thank you for the information. I will update the first post once I have more time.
Do they have the same graphics for a 2500 hood?
Only if GM made the carbon fiber edition for the 2500. Im sure you could make the 1500 work for it, obviously need to tweak for the air inlet on 2500. There may be an aftermarket company making replica stickers also
Did they change the engine bay/battery location on the new trucks or is this a 2500? Edited by sierraguy2015
That's a pic of a 2500s springs from factory on one that was in the shop. Just showing them so people don't wonder wft if they get a set that color. The actual springs are quite a bit bigger than the second set of replacement ones we had in the parts room. The ones I ordered were the same gold color but you may also get a factory set with the same sized black springs as a 1500 but with a long bracket.
Just wrap it yourself and use knife less tape. It should be very straight forward. Allows for customization and will save you money
