The module that takes care of the TPMS and door locks is called the RCDLR and usually sits under the dash pad. These can fail especially if water gets in there.
Coby7, thanks for this. I did get water in the dash somewhere because I saw it on the floorboard below the dash after I realized it was dripping from the headliner.
Ultimately the RCDLR got replaced today. I think the service adviser had the wrong name for the module. Anyway, sharkfin leak fixed and RCDLR replaced. All is working well at the moment. C'mon rain, let's see if we still have a leak.
  • 3 months later...
  • 1 year later...
Just wanted to add my two cents to this older post. I have a 2016 GMC 2500 Denali Diesel. A few weeks ago I noticed that my FOB would not lock or unlock the doors. The alarm would set, but the door locks would not move. Of course this meant that when you opened the door the alarm would go off. This happened 1300 miles out of warranty (of course). I drove it to a dealer for trouble shooting. GM tech told the mechanic to replace the body control module. The mechanic did that but it did not fix the problem. Since I am on vacation and needed my vehicle back the dealership could not continue working with GM Tech hotline to trouble shoot further. Now my alarm will not set and the door locks still do not operate. I will have to follow up on how this problem when I get home. Not sure how this problem will be resolved. GM agreed to pay the cost outside of the warranty period. It would have cost me $547.00 for parts and labor and in this case it didn’t correct the problem anyway. So far I have not been charged for anything. GM has 80 cases of this problem ongoing according to the dealership. Ask for your area or zone rep and talk with the factory before agreeing to pay for this type to of repair. Factories have cash that they leverage for repairs that are not the fault of abuse but of poor engineering. This is not an owner problem. More to follow when I know more.
Couple months since I created this post, but here is/was the issue. I took the truck to a different dealer he asked me to leave both key fobs for reprogramming and changed a blown 10a fuse. So it wasn’t the body control module in this case, just a blown fuse. A few months later and the same thing happened. Deciding I didn’t want to pay another $150.00 dollars to have a mechanic change a fuse, I did it myself. The only problem is I didn’t know which fuse it was. I discovered by pulling each fuse that it is located on the passenger right side fuse block upper left 10a fuse. I replaced it with the spare 15a as I did not have a 10a left in the spare slot.(probably used by the mechanic on the first repair). The owners manual has this listed as “Body Control Module 8” vice “door lock”. I don’t believe I needed to have the fobs reprogrammed in the first repair. I didn’t do that this time. I think the additional 5amps in the fuse will prevent this from happening again although I don’t know what the engineers would think of the increased amperage.  I have a bad habit of hitting the fob buttons too many times in a row which might cause too much stress on the circuit. I will try not to do that. Hope this helps.
Edited by JNK13
  • 7 months later...
  • 5 months later...
Do you mind providing a follow up here as to if you’ve had any issues since the fuse replacement?
This is a great write up, and I’ve been having the same issues.
when one fob works, the other does too. When one DOESN’T work, neither does the other. I also had TPMS sensor error as soon as this happened as well.
they work intermittently, and it seems as if they have a mind of their own (work one day, don’t the next).
follow up post on the success would be much appreciated.
Hi Travis1024,
After replacing the fuse to a 15amp I had no further issues with the circuit/fuse blowing. It’s my belief that the 10amp circuit probably couldn’t handle someone like me who has a bad habit of hitting the FOB buttons multiple times to unlock the doors. Good luck and thanks for the compliment!
Did the RCDLR replacement Ultimately fix this? Any issues since the fix?
Hi Travis. Yes, this fixed the problem and there have been no issues since.  The sharkfin antenna did leak one more time but it came through in a slightly different spot so no electrical issues because of it and the dealer must have really sealed it well this last time because it hasn't leaked since.
On 12/14/2019 at 3:50 PM, JNK13 said:
Hi Travis1024,
Thanks for the follow up. I too overuse my clicker out of habit haha.
Looks like Mike (below) had the same issues, but with a different fix replacing the RCDLR. I think I will try the fuse route first to see if that works.
Thanks for following up, Mike!
If you don't mind me asking, did warranty cover the RCDLR replacement? (if you are still under warranty of course)
Travis, yeah both sharkfin leak repairs and any work related to it including RCDLR was covered under warranty.
