Disable automatic headlights and daytime running lights
DRLs are mandatory here in Canada.
I have a US-issued 2015 Silverado LT. I have not done anything to the factory switch. If I turn it to "OFF" then let it spring back to the AUTO position my DRL's turn off. I have done it while in Drive and know it works that way (while sitting in traffic with my foot on the brakes I can see my lights go off in the reflection in the car in front of me). They stay off until I spring the knob to the left again to re-enable auto lights or until I shut off and restart the truck (which re-enables them too).
Edited by sk
If it was dark when you last used your truck they will be on when you start it even if it's daylight. There's a hysteresis timer and it takes a couple of minutes to switch. This is so they don't turn on and off when you hit a shadow area like an overpass.
:crackup: Not sure if you're a guy or girl but I guess you're not a very patient person then if you can't wait 1 minute for the ambient light sensor circuit to shut them off for you. Personally I find it works perfect the way it is. Meet to many non GM cars at dusk or later with no lights on. Daaaaaangerousssss in my opinion. Please don't take this personally I'm just observing here and just don't understand your need to pull out this spring in the switch. Let a sleeping lion sleep. I pray to GOD you don't hit a biker this summer because he didn't see your lights.
Edited by Coby7
Auto lights and DRLs are two different things.
I know that.
What I am telling you is that on the 2014/2015 Silverados the upper headlight (low beam) is used as the DRL during the day. If you turn the dash switch to the left it disables ALL the lights (DRL, parking lamps, and auto-headlights) and you can drive without any lights on. So it DOES disable the DRL's but it only does it until the truck is shut off and restarted. At that point the DRL circuit automatically re-energizes until you turn the switch again.
Again this is for a US truck. I don't know if the Canadian DOT laws work the same way.
Exactly right sk. Coby, read sk's post. This isn't only about the auto headlights it's also about the drl's. Every time I drove my truck in the daytime the lights were on full time. Nice sleeping lion quote. Here's one for you: If it ain't broke don't fix it, - Gm full time headlights are worthless except to get you to replace them more often. I'm not sure how I eeked through my first 50 years of driving without headlights in the daytime for safety. Lol
Edited by Lidd
