Huge thanks to pgamboa not only for making the harness (which works flawlessly) but also for being so helpful. I asked a ton of questions related to mirror part numbers, install questions and even texted him while I was installing to get some quick pointers. Fantastic stuff and I would def buy again.
One question for anyone that has one this install. Have you noticed your upper mirror shake at all? Mine seems to have a small shake to it, unsure if I just don't have it torqued down enough of there is just always a small shake in the mirror. Anyone know torque specs for this thing? I don't want to torque down too hard and snap off a post.
Thanks for the feedback! I'm hoping someone with Towing Mirrors can offer some advice on your issues. The retrofit doc does say to tighten bolts to 9 Nm (80 lb in) if that helps.
Just curious, I dropped off my 14 sierra Denali to install the oem tow mirrors without the power fold option with the LH Door Harness 23171572, RH Door Harness 23171566 and Jumper Harness 23387133 and I was told it's a 7 hour job for a total $485. I told them forget it and I'd come pick it up. That sounds way out of line. Anybody else have this issue?
It takes me about 30-45 minutes for each door to swap a harness out. But I've done it over 100 times. I think on average (from my observation here), is that an hour for each side sounds about right. Factor in swapping the mirror, drilling the 4th hole, etc., you might be a 1.5hrs. (Maybe 2 if it's your first time). Now - That's just for mirrors and door harnesses.
For the jumper harness, that is a little more involved. One member completed his jumper harness in 3-4 hours while another took 8-9 hours.
It doesn't help that the jumper harness installations instructions are not the clearest which is why I decided to make the How To video On that jumper harness.
7 hours doesn't sound too far off, but I would imagine that time be shorter since the dealer is installing versus self-installed.
Hope this helps.
One other thing - Your truck is a Denali. I presume you have Seat Memory? If so, those harness part numbers won't work. What they quoted is "Minus A45 - Seat Memory".
You want (If you have Seat Memory - A45)
Part # 23171564
Replaced By Part # 23342727
Part # 23171567
Replaced By Part # 23342716
Edited by pgamboa
Hope this helps.
Thanks, I figured it sounded a little far off. Time to get other quotes from different dealers and compare.
I also updated my reply with the correct harness part #s. Good Luck.
I do have seat memory but before I purchased the mirrors and harnesses I provided my vin and they told me I'd need those specific harnesses and to have the memory module reflashed for everything to work. I hope this isn't another issue I'll have. I just got my headlights retrofitted and that turned out to be a 2 month long disaster. I can't handle any more problems at this point.
Edited by boricua2480
If you have seat memory, I guarantee these harnesses will not work. I provide a vehicle acceptance retrofit chart and it clearly shows different part numbers if you have seat memory. For what it's worth, I also noticed a typo on one of the harness part numbers on the chart as well.
I've helped over 100 members on this forum successfully complete this upgrade. I have documented over 40 different harness part numbers. I am 100% those harness part numbers will not work for you. Sorry to be the bearer of bad news. But want you to know ahead of time.
I don't know how or why dealers are still continuing to give inaccurate information.
Just curious, the harness part numbers I provided are different than the ones you mentioned that were replaced by new part numbers. Am I missing something? Bear with me, this is all very confusing to me so I apologize if I'm asking a dumb question.
No need to apologize.
It is common for part #s to become obsolete and replaced/superseded by new part #s.
If you have do NOT have Seat Memory - A45:
Part # 23171572 has been replaced (superseded) By Part # 23342729
Part # 23171566 has been replaced (superseded) By Part # 23342715
If you DO have Seat Memory - A45:
Part # 23171564 has been replaced (superseded) By Part # 23342727
Part # 23171567 has been replaced (superseded) By Part # 23342716
Edited by pgamboa
Another happy follower!! Successful DL8 to DQS (power folding) upgrade in a GMC Sierra 2500. All the information is accurate and on point. Look no further if you are trying to upgrade your mirrors...
Thanks Hsilverstein! For anyone looking to perform this upgrade, let me guide you in the right direction. I commonly see misinformation given by the dealer time after time again. I can make this plug and play for you. For any DIYers, save yourself some time, $, and the headache of being misguided. You can do this upgrade yourself.
PGamboa! You're the man!
As a GM tech I've never seen such attention to detail in a harness. It's as if they were ordered directly from GM. You can't tell the difference. Terminal pin crimps and pin fit is perfect and of course they work as they are designed to. If you haven't gotten them, I don't know what you're waiting for. Thanks again for a great addition to my truck Phil.
Edited by Justin101714
  • Like 3
Coming from a GM Tech, this is very welcomed feedback! Thanks for sharing! I put a lot of effort in making this upgrade not only possible as a Plug and Play solution, but with quality work. I am very passionate about doing things the way it would have been if it came from GM. Using the same gauge wiring, same terminals, same crimping methods :), and same automotive harness tape. I would not put out what I wouldn't personally install on my truck.
Thanks again for sharing your upgrade! I get great joy in helping others achieve this upgrade and enjoy seeing the results!
  • Like 3
