Wanted to post about another successful tow mirror upgrade with pgamboas harnesses and mods to the 1AAuto tow mirrors.  I know this thread is full of success stories, but I need to point out how much pgamboa went above and beyond for my install.  Issues with the mirrors, that had nothing to do with his mods or my install, but he took it upon himself to get them all resolved.  It took three sets, but eventually everything was taken care of and I have the mirrors and functions I wanted.  I would have quit and gone a different route much sooner than pgmboa.  He really stuck with it and got me all fixed up.  Kudos and thanks.
  • Like 3
I am new to the forum and have been researching towing mirrors for my 2015 Chevy 2500HD LTZ gas since we purchased a LQ horse trailer.  I am planning on giving this truck to my daughter so she can trailer her horses around when she turns 16 (couple of months).  In 2015 and 2016 I asked a dealer if they could put towing mirrors on my truck and was told it would need a new harness and they didn't have them yet.  I have not contacted a dealer since and decided I need to do this myself, but after reading 100,s of posts, I am still confused as I have one of the earliest 2015,s made (feb/2014).
From reading pgamboa posts have a wealth of information and I think I understand most of it, but I hoping he or someone can let me know exactly what I will need to upgrade my DL3 to the 1AAuto mirrors 1AMRP01786 (if I even can).
2015 2500HD built in Feb/2014, LTZ, gas with options AY0, A45, DL3.  It does have the memory seat option.  I am pretty sure I will need at least the 2 wiring harnesses and I live in the Dallas/Fort Worth area. My truck was in the body shop for over 2 months getting hail damage repaired and I just got it back.  I have not bought any of the parts yet but will once I know what I am up against.  The main things that are important to me is the power fold, power adjust, and turn signals.  I really want to get towing mirrors on before my daughter get her license.  Thanks everyone.
Well, the good thing here is that I live in Dallas too :). PM me and can work something out. Copy/paste this info into a PM to me.
Thank you pgamboa......I will update the thread on how this works out.  When I bought this truck, the dealer told me it was one of the first 2015,s for the new model year and apparently, they did some changes later in the year.  Once I get the mirrors on this truck figured out, I have a 2017 GMC 1500 that I may put towing mirrors on and hopefully, it won't be as difficult.
Just came apon this site I just got mirrors for my 2015 gmc 2500hd had the dl3 mirrors on it with all functions trying to up grade to the full function tow mirrors but my fold and markers lights not working if I were to order your wire harness would this fix my problem or is that for a different vehicals and or set up also how would I go about ordering this and or would u happen to know the wiring diagram for the a1auto mirror configuration
Phil, been reading through the thread and done tons of searching to no definite avail.
I have a 15.5 GMC CC/SB SLE and have the DPN mirrors. I got a good deal on the DQS mirrors through a local dealer and have obtained the correct powerfold/adjust switch. Do I need to purchase the harnesses as well?
Hey there. If you currently have DPN Mirrors and have all the lighting circuits functional (Turn, Cargo, and Park Lamps), then you would be probably the ONLY case where you wouldn’t need a harness.
Are your DPN mirrors the newer style with all the lighting features present and operational?
Has anyone gone from DL8 to DQS on a 04/14 built, non AVF 2015 2500 diesel with K40 (exhaust brake) and no memory seat? Assuming I only install DQS mirrors and the driver side mirrow switch will I get powerfold to funtion as Im told they ARE pre wired for this? Most forums Ive read go from DL8 to DL3 or DPN to DQS. All GM dealers Ive spoken to tell me its not possible and blow me off but Ive learned not to believe everything they say since they also sold me DPNs assuring me they were powerfold. I'd like to be sure so I can get the correct DQS and door switch and hopefully prove my local dealer wrong.
I am currently doing this upgrade. I bought the aftermarket DQS like mirrors when I currently have DL8s on my 14' LT 1500
list of what you need
door harness from PGamboa
DQS mirrors
powerfold switch (there are 2 different choices, so check your current switch first)
and
if you check your body harness by the door (details in the first post) you will see if you need the added pins to the connector.
I bout these because they were cheaper than those because they are verified to be the exact same thing for a cheaper price. Or you can chase down the factory DQS mirrors.
hope that helps
Thanks for the reply. I verified that I DO need the RZY harness because I'm missing pins #9 and #11 on my body harness. What I am interested in most is the powerfold function for the meantime. From my understanding the rzy harness only adds circuits to the lighting functions. I wonder if the fact yours is a 1500 differs in application to mine aside from considering the exhaust brake and ambient sensor on passenger side. Does yours have memory seats? Mine does not have memory seats. Just want to confirm if buying dqs and powerfold switch will be enough to give me powerfold, power adjust and heat.
    I know eventually I will need to install RZY jumper harness and additional door harnesses to get full light features.
Here is a brief section I copied from a bulleting or instructions from gm ".......This upgrade is ONLY for the models listed below, and is NOT recommended on 2015 models without RPO AVF or 2014 models, due to electrical differences in the fuse protection."
  Then further down it states this "
Trucks built at Flint Assembly, 11th VIN position “F”
Note: DQS Camper Mirrors are NOT RECOMMENDED for upgrading NON-FLINT BUILT TRUCKS"
Thus confusing me more because my truck is a 2105 model without rpo AVF but WAS built in Flint, MI 04/14
Thanks for the reply, Phil.
I have all the new features of the newer tow mirrors. I'm thinking I may need the harness because everything works on the mirrors - lighting wise - but not the power fold and adjust features.
You are correct in that the RZY Harness ONLY adds the lighting circuits to the door jamb connector (body side).  The RZY has provisions to add the Cargo Lamp, Running Lamp, and Turn Signal.  In most cases, most trucks have the turn signal (pin 41), so the RZY will essentially add the Cargo and Running Lamp.  RZY has nothing to do with Power Fold.
On trucks WITHOUT Seat Memory, the power fold circuits on the mirror connector are on Pins 4 and 18.  These circuits come from the door panel harness (from the power fold switch).  It splits off and hits the driver side mirror, then to the door jamb, then over to the passenger side.
On trucks WITH Seat Memory, the power fold commands (from the power fold switch) hit the driver side mirror (same pins 4 and 18), BUT they don't go the passenger side this way.  With Seat Memory, the passenger side mirror adjust and mirror fold are done via a Serial Data Bus Circuit.
The reason why GM Says  'This upgrade is ONLY for the models listed below, and is NOT recommended on 2015 models without RPO AVF or 2014 models, due to electrical differences in the fuse protection." is because on all 2014 and 2015 without AVF RPO, these trucks will NOT have pins 9 and 11.  Not because of "Fuse Protection" but simply because the circuits are not present.  The other reason why it states "not recommended for non-flint built trucks" is because of the 4th hole needed for the extra stud.  That's all.
There have been NUMEROUS members that have completed this upgrade.  Out of the 350+ I've helped, ONLY 1 has had a problem with power fold.  The passenger side doesn't power fold, but the driver side does.  There may be an underlying issue we haven't found yet and still working it out.
If you PM me with you info, we can confirm things before you make a purchase and guide you down the right path.
So, you are saying that you've installed the DQS mirrors with the stock harnesses that worked for the stock DPN mirrors?  And they don't power fold?  I'm a little confused.  Maybe I'm missing more to this.
Thank you very much Phil. It all makes sense now. What all do you need me to PM? VIN?
Let’s start with a pic of your glove box RPO List. Then your year and trim. Let me know what you have know and what you want to upgrade to. This way, all the requirements are captured in the PM. I get tons of PMs, so they drown very quickly.
