I have a 2014 SLE All Terrain. The functions of the mirror are power adjust/tilt, folding, signal, and puddle light. I would like to either upgrade to OEM black, or the A1 Auto mirrors. Could you give me some insight on what is needed after the mirror purchase. Or your mirror purchase recommendation?
think all that info is already covered in this thread.
Please read the first post in its entirety. Not explains the requirements for 2014.
If you go aftermarket, the best bet is to order and ship to me so I can ensure the mirror is PnP when it gets to you. But please read about the 2014 and the RZY Jumper harness requirements.
Thanks,
Thanks,
By reading your post it looks like I currently have the DL3 on my all terrain SLE and I would like to upgrade the DLQ. Once I find these, can you tell me what options I have for the plug and play harness. I understand you make these, can you tell me which one to order purchase and how from you. Thanks
I recently decided to upgrade the stock DL8 mirrors on my 2015 Silverado to the DQS power-fold towing mirrors in an effort to get the truck out of the weather and into my garage this winter. Pgamboa provided me with a kit, switch, and detailed instructions on how to make the aftermarket mirrors from AM Auto operate like factory originals. Luckily for me I came upon this thread doing a search on the modification. Not only were the parts he provided of the highest quality and the instructions better than some factory manuals I've read, pgamboa was like having an online assistant during the entire process. He took the time to answer some beginner type questions on the Labor Day weekend!
I wanted to take the time to thank pgamboa for all his assistance in making my holiday weekend project a success. Aside from this forum being a constant source of great information and camaraderie, its people like pgamboa that make it not only possible, but fun to tackle these modifications.
Edited by tjstawicki
  • Like 4
Send me a PM with this info. Will need to ask additional information about your truck.
Hi,
I am upgrading my '17 Sierra from stock power mirrors to tow mirrors. I have to install the female pin terminals to the door side harness for the blinker/courtesy/markers lights. Does anyone happen to have the part number and or a picture of the terminal that I can take to the dealer? I have searched on here but cannot seem to locate a number, Any help would be great!
Roy
Ok so I figure after reading this and some others I have the DL3 "premium" small mirrors, and I want the DQS power fold tow mirrors.
Would anyone want to buy my DL3's!?
I have seen some sets of tow mirrors on eBay for 250 and as high at 1700 (cdn). Some of these say they include everything needed, some not so much info. How do I know I need your pnp kits?
I found a set on 1a auto, for a 2500hd Denali diesel https://www.1aauto.com/mirror-pair/i/1amrp01796?f=1103291&y=2015but it's not power fold
Then there's this kit says for a 1500 but clearly states K40 diesel exhaust brake option and power fold
Would I still require a pnp kit to make these work as factory. I think the second option also has the puddle lights as a bonus, whereas the stock dqs do not. I'm leaning one the second link as it's a cheaper option and looks complete. Anyone tried any of these?
Thanks in advance
Dan
2015 GMC Denali 2500HD diesel
Thanks in advance
Dan
Dan, if you have Diesel, you must get a mirror with the K40 Option. This is the temp sensor on the passenger mirror and will throw a CEL error if you don't it have it present. As for tow mirrors, most after market mirrors will require some customization. There is only Set from 1A Auto that won't next Customization, but that set is not power fold. In either case, you'll still need harnesses.
Edited by pgamboa
Ok, so I'll still need a harness from you. As I do want ALL features to work
I believe this is the mirrors that will work
https://www.1aauto.com/mirror-pair/i/1amrp01798?f=1138967&y=2015#product-qa-tab
Of course my luck says it's out of stock! I'll send the c note to find out if when they'll get more.
Can you let me know which of your harness(es) I'll need?
Would I buy from them and ship direct to you?
The only feature I'd do without is the memory mirror, if that's the separate RZY harness. And if that's all it does, but I still want tilt with reverse and all other options, key fob or button powerfold, power, heat, led signal, led spot reverse or cargo, (and puddle, but only cause this mirror wil have it, but I do have the headlight switch off mod so the factory ones don't come on now anyways)
Thanks in advance!
It truly is people like you on these forums that make these seemingly complicated tasks manageable for us unsure people
Thanks in advance!
This would be the compatible model. As for the harnesses, I build them based on your trim and mirror you select. Once you have decided on a mirror, I'll have payment instructions sent in a PM. As for knowing if you'll need the RZY Jumper or not, it would be best to confirm what is present/not present in your door jamb connector. Please see the 1st post and confirm if you have pins 9, 11, and 41. You should have pin 41 since you should already have Turn Signals. If 9 or 11 are missing, you'll need the RZY first before anything.
Anyone have a factory loaded driver side mirror they would like to sell? Was just involved in a hit and run cracking the plastic on the bottom half of my mirror.
Tow Mirror or smaller DL3 Mirror?
Have DL3's I'd like to sell but I would only want to sell them as a pair. They are factory paint matched black
