Joe,
While I haven't physically had my hands on harnesses - 84125571 or 84125561, my search shows that these part #s are the newest part #s. As a matter fact, when i search for 23342727, several websites show that the updated part # (or part # that has replaced it) is 82145571. And the same for 23342716, shows that 84125561 is the updated (superseded) part #. Either of those should work for your truck.
I also did a check on ebay, and those part #s reference each other. So either set should work.
Thank you VERY much! So it looks like I am halfway there... now I only need the DQS mirrors. Not needing to remove both door panels and swap harnesses, I may be able to tackle this one myself.
You will need to remove your door panels to swap the mirrors. The molding that covers the mirror bolts, is underneath the door panels unfortunately.
Hi Guys,
I'm new around the forum and I also have a similar truck as JoeM21. 2017 silverado 2500HD LTZ, Z71 Midnight edition. It came with the small mirrors also and I want to upgrade them to the bigger one tow mirrors. Now, currents ones are powered fold, turn blinker, heater I guess also. I see on GM part online the only upgrade are this one https://www.gmpartsonline.net/oem-parts/gm-mirrors-trailering-black-23372182/?c=Zz1leHRlcmlvciZzPWFwcGVhcmFuY2UmYT1jaGV2cm9sZXQmbz1zaWx2ZXJhZG8tMjUwMC1oZCZ5PTIwMTcmdD1sdHomZT02LTBsLXY4LWZsZXg%3D Which are the part# 23372182 and I see Joe saying something about DNP. What exactly is the difference btw DNP and DQS? Seems a lot of trouble with all these tow mirrors and harness. What do I actually need? Are those prices on the GM website for a pair or just one side? because I dont see the description saying otherwise left or right just Kit, assuming both. Thanks for the help in advance. Here are some pics of the truck.
21199549_1442903165786080_15826583210636
21167647_1442903169119413_52131808593962
21273392_1442903162452747_20496910071977
Edited by Yoandry
Hi Guys,
you really should actually read through the thread here. Would answer your questions about the different types of mirrors......you gotta do your research first then come and ask questions.
2015 1500 LT Silverado Midnight Edition
Hi Guys,
Most of these questions are answered in the first post of this thread.
Thanks.
DO you sell the OEM DQS one + the harness for each door? Can you PM me with price /part needed. Thanks
I do not stock mirrors, just harnesses to support the upgrade.
Harnesses are $225 shipped (this info is also in the first post).
Part #s for mirrors:
DQS Power Fold - Chrome Towing Mirror
Part # 84041609 - Driver
Part # 84228892- Passenger (Gas)
Part # 84228894 - Passenger (Diesel - K40)
Do you have the part# for the black one instead? I can't find any of those option #s under my model/accessories. Damn GM website.
About the harness, I know yours come PnP ready right, meaning if i get the one from from GM "84125571 and 84125561" I will have to do the pinout staff, right? Thanks
Edited by Yoandry
DQS Mirrors only come with Chrome Caps... caps are interchangeable though.
Pgamboa looking forward to working with you on this installation and appreciate all feedback. Thanks in advance.
INSTALLATION REQUEST
Chrome power folding towing mirrors with the same functions as current if possible.
1) What is the part number of the power folding mirror I need to order?
2) Which harness will I need (assume order from Pgamboa)
TRUCK INFORMATION
2017 Sierra 1500 4WD Crew Cab SLT
5.3L V8 ECOTEC3
CURRENT MIRRORS
Power folding
Blinker
Puddle lamp
Reverse adjust
Seat memory
Heated
BUILD SPECS
Truck
Thanks to all -
Joey
Can't say enough about Pgamboa!!! I was referred to him by the vendor that I bought my upgraded tow mirrors from. I have a 2014 Chevrolet Silverado LTZ ext cab 5.3 gas pickup. I replaced the OEM DL3 to the DQS towing mirrors and was able to swap out harnesses with ease due to Pgamboa's detailed instructions. This was after installing the RZY harness which pgamboa's video tutorial was invaluable in assisting with the process. Thank you so very much, all of the functions on the new mirrors work like a charm!! Highly recommend Pgamboa!!
Very glad to here. I commend anyone who has to install the RZY Jumper Harness. It is a PITA to install. LOL.
Here is a pic of the Cargo Light on with Reverse Light. The mod occurs in the BCM. Between the brown and pink connector. It's pin 26 of the brown connector going to pin 26 of the pink connector. Stripe of the diode is towards the pink connector. Diode is 1N4004
Pgamboa thank you for your help!! I was also wondering about the mod for the front ambers on the tow mirrors to make them work with the turn signals? Also send me your address, I still have my stock door harness that I'll send you! I don't have any use for them anymore and they are just sitting in my garage.
Pgamboa was a HUGE help for me in the process! i got rid of my tiny DL8 mirrors and slapped on some aftermarket tow mirrors. I used his DIY harness and it was a breeze to install! Instructions were very clear and pictures helped a TON! He is a great resource for the project! I also had to install the RZY harness as I have a 2014. my truck was wired for turn signals already but not the running/clearance lights or cargo lights.
If anyone is going to attempt the RZY harness install i recommend watching pgamboa's video and having the written instructions handy, it is a massive PITA to put in. Took me about 6 hours to install that alone! Start on the drivers side first as all the BCM connections are there, when that entire side is done you can put the BCM back before wiring the passenger side.
Pgamboa was a huge help and trust me, I asked a bunch of questions. From which mirrors (aftermarket vs OEM), to pre-instasll questions, to texting him (he gave me his #) all day long about some install troubles I had. He bent over backwards to make sure that I had all the knowledge I needed. His videos are great and and his tutorials help tremendously. His harnesses work great and he's great guy to do business with and talk to!
If you're thinking about doing a tow mirror upgrade, he's your guy to help bring clarity to your decision and help you ALL along the way!
