Pgamboa-
I think I may have messaged you  a while back about this same thing but couldn’t locate the message.  Sorry if it’s repetitive.
i have a 2018 Silverado 1500 lt z71 with the DL8 mirrors.  I want the tow mirrors with all the functions (including power fold).  Does your complete harness provide all that functionality?  If so, could you link me to the mirrors i’d Need to purchase?  I was hoping to get ones with smoked forward facing Markers in black (not chrome).
Also,  do you have any experience with boost auto parts?  They sell a tow mirror with all the functions plus a switchback style led instead of the standard Amber forward facing led marker.  Was curious if your harness would work with that specific mirror?
any guidance is appreciated.
-matt
Edited by RadoRage
Pgamboa-
-matt
Matt,
My harnesses provide all that functionality provided that the mirrors are wired up to factory tow mirror specs. I have not had any experience with Boost mirrors so I cannot comment on how they are wired to. With a switchback running Lamp/turn signal assembly, I would expect the wiring be landed to the plug so you can just plug it in... especially at the price they are asking.
So as long as their mirror has the light circuits landed to the factory spots on the plug; then it should work.
The mirrors that I have access to are GM mirrors. So if you want switchbacks, smoke, or any other customization outside factory mirrors, you’d have to source them yourself.
4 minutes ago, pgamboa said:
Matt,
Ok thanks.  So what is the cost of the whole thing (GM mirrors, harness, replacement switch (unless I’m missing a part).  Do you have a complete kit price?
-matt
-matt
$1058 - GM Power Fold Mirrors (chrome Caps or black textured caps - same price)
$285 - Harnesses
$70 - Switch.
$1413. I refund $100 if you send me your factory harnesses.
On 2/22/2017 at 2:55 PM, pgamboa said:
All,
Due to the overwhelming interest in folks wanting to upgrade their mirrors, I wanted to start this thread, hopefully, with all the information pertaining to the process of upgrading your mirrors, the different mirror types, the GM supported upgrade path, the non-GM supported upgrade path, what all is involved, and any known issues.
I receive about 15-20 PMs daily around this upgrade. I will try to respond to all as I am able to. Please read through this entire 1st post in its entirety as I hope it answers all your questions. I also hope that this thread is your “one-stop shop” for all questions surrounding this upgrade.
I have spent MANY months (since June 2016) trying to understand these mirrors and what all is involved to make the upgrade successful. Like many of you reading this thread, you have probably spent countless hours researching online, reading threads upon threads, and watching YouTube videos for some info and guidance. For those that have tried this upgrade on your own, you have probably ended up with the same results of something not working correctly, which ultimately landed you back here on the Forum.
I have helped numerous members here achieve the same upgrade desires with success. This started out with me wanting to upgrade the standard DL8 Mirrors on my 2016 Silverado, 1500, LT, CCSB, 5.3L Gas Truck. I have helped members with Standard DL8 Mirrors upgrade to DL3 Mirrors as well as members wanting to upgrade to Towing Mirrors.
So, let’s get started…
Mirror Types:
DE2 Mirrors - These are the basic mirrors found on W/T Trucks. They do not have power anything. They are manual adjust, manual fold, etc.
DL8 Mirrors – These are the most common mirrors found on LT/SLE trucks and are the next level from DE2 Mirrors. DL8 Mirrors are Heated, Power Adjust, and Manual Fold. If your truck has 1LT/2LT options, this will most likely be the same mirror.
DL3 Mirrors – These are mirrors are the “Premium” version to the DL8 Mirrors that most folks are wanting to upgrade to. These mirrors are typically found on your higher trim LTZ/High Country and SLT/Denali trucks. These mirrors are: Heated, Power Adjust, Power Fold, Turn Signal, Puddle Lamps, and Auto Dim (Driver’s Side).
Towing Mirrors – These mirrors are the larger mirrors designed to help with towing. These mirrors can be found as options in some 2500/3500 Heavy Duty Trucks. They come in (2) main flavors.
  • DPN – These are Manually Folding, Manually Extending, Heated, Turn Signal, Cargo (also referred to as Courtesy Lamps), and Clearance Lamps (also referred to as Park/Running Lamps)
  • DQS – These are essentially the same as DPN except they are Power Folding and supports Mirror Memory if your truck has this feature.
Aftermarket Towing Mirrors – There are TONS of aftermarket options out there. The result should be the same (for the most part) on the upgrade. The way that manufactures “pin” their connectors, they typically pin them the same as the GM - OEM ones. Watch out for any Manufacture that says they have the “option” of adding a separate harness or connector for added functionality. If it’s not already in the connector, I would stay away from those or contact me for mirror connector customization.
[/url]
Note: RPO Code - K40 Option (Exhaust Brake) for Diesel Trucks. If you have a Diesel Truck, you will NEED to get the appropriate DL3, DPN, DQS Mirror WITH the K40 Option. This is basically a temperature sensor on the passenger side mirror. Without this, you will get a Check Engine Light (CEL) error come on with an “Ambient Temperature” message on your DIC (Driver Information Center). This is NOT an issue with Gas Trucks. You can install a passenger mirror with the temperature sensor on a gas truck with no issue (I am using a K40 optioned DL3 Mirror on my truck).
Here is a video I put together on the entire process. This video covers the following:
  • Removing the Door Panel
  • Removing the Door Harness
  • Installing the Power Fold Switch
[/url]GM Supported Upgrade Path – Upgrade DL8 or DL3 Mirrors to Towing Mirrors:
If you do need the RZY Harness, I created a "How To" Installation Video here:
Here is an additional video showing the detail of the RZY Harness.
Non-GM Supported Upgrade Path – Upgrade DL8 Mirrors to DL3 Mirrors.
2014 – Known Issue:
WT/LS – Trim Owners:
Custom Plug and Play Harnesses – $285 Shipped to (50 US States - for Canada, please add $47.95)
Custom DIY Kit – $65 Shipped (Ships First Class Mail with Tracking - for Canada, please add $10)
I will also provide you with ANY information regarding this upgrade even you don't buy from me. My goal is to help everyone achieve their mirror upgrade goals.
If you decide to move forward with ANY purchase or if you have additional questions, please let me know. It is helpful to know all the details of your truck to provide the best possible solution.
For example:
2016 Silverado, LT, 1500, Crew Cab, 5.3L Gas.
Thanks, everyone! Hope to help as many people as I can to achieve this upgrade!
Please enjoy this Time Lapse Video to get an idea of what is involved with the customization of the harness. Each set takes about 1hr to modify, plus another hour test. So a completed set is roughly 3 hrs to build and test.
How to remove the DL8/DL3 Mirror Caps.
How to remove Tow Mirror Caps.
All,
Mirror Types:
[/url]
2014 – Known Issue:
For example:
So I have a 14 GMC Sierra 2500HD and want the 1AMRP01786 mirrors from 1Aauto but they tell me they wont work! Can I make these work, I dont have power fold now. Thanks, Jerod
Yes you can. But since you have a 14, there will be an extra harness needed for the inside cabin. GM didn’t and the tow mirror light circuits to the door jamb. You’ll also need a custom harness built by me, jumpers for the mirrors, and a switch. I can provision this all. PM to order. Also, I have links to AM auto part #s for the same mirror, but less than 1A Auto prices.
Ok so what will I need from you and what will it cost? If I buy the mirrors#1AMRP01786 and switch# ACWES00001 from 1aauto. Or do you have somewhere else to get mirrors and switch?
Are you diesel or gas?? Black caps or chrome?
@Jerod P, you said you are a 2014 2500HD correct?  @pgamboa if that is the case, he is still a GMT900 series truck and not a K2 and that may change things.
[mention=197382]Jerod P[/mention], you said you are a 2014 2500HD correct?  [mention=159655]pgamboa[/mention] if that is the case, he is still a GMT900 series truck and not a K2 and that may change things.
Oh yeah. You’re right. OP, we’ll need to validate some things to be 100% on your build.
So will any of the aftermarket power folding mirrors work on this truck? Will they physically mount, and can you wire them to work? If they will mount......it seems like there is a way to wire them or am I wrong?
