FS: CK156 20" replicas with Good-year SRAs
Darth_Vader
Remove the tires and look inside. Had the same exact issue with a family members new tires wouldn't balance. Removed the new tire after it wouldn't balance And a tech forgot to remove the temporary metal band that holds the Tpms in place while you mount the tire?
I'm not 100% sure what went down lol but that could be the issue.
  • 1 month later...
I think it is because the hub on these are bigger than the stock hub and I didn't run them with rings, I am going to try and measure them tomorrow. They are probably perfectly fine as I never had an issue on my 2-door Tahoe with them, the question after that will be if I want to sell them so cheap, lol! A cheap fix if all they need is hub-centric rings!
