Letter - Cycling Thermostat
Has anyone gotten a letter from GM regarding cycling of the thermostat creating stress fractures in the radiator on 2014 5.3s and 6.3s? Anyone experience the issue? I love this truck but the number of recalls and TSBs is greater than anything I have owned before. First model year blues?
I've only had my 14 for the last 25k miles. It currently has 70k on it. I haven't gotten this letter yet but I sure don't want to replace the radiator. I have already got to replace the upper a arms because of worn out ball joints. Seems they just about have engineered failure to 3 years now. Since I have had the truck, a little over 14 months now, recall on the hitch, seat belt and now a cycling thermostat or worse a cracked radiator.
I had this same issue last year.. I searched this forum and found a lot of info.. I called the local dealer and made an appointment.. I went there and told them all the info and the service guy was clueless.. I told him your tech is going to check the truck and he's gonna find the leak.. then your gonna call me and say yes there is a leak like you stated.. then your gonna order up a new updated radiator and thermostat for the truck.. and I also told the service guy the recall code.. which I don't remember now.. and my goodness when I pick up the truck the service guy said do you work for gm... I step back and smile and other employees are looking at me and I said no...
  • Like 4
I see from your signature that you have a 15', so I guess this issue is not exclusive to the 14's as the letter implies.
i got the letter a couple days ago. im curious where the t stat is and if the fix is a new t stat and new rad.
no clue if mine has this issue or not... ill mention it at my next service.
#15829: Special Coverage - Radiator Leak - (Nov 9, 2016)
Subject: 15829 — Radiator Leak
999999995.gif Models: 2014 Chevrolet Silverado LD 2014 GMC Sierra LD
Reference Number: N15170099
Release Date: November 2016
Revision: 00
Make
Model
Model Year
RPO
Description
From
To
Chevrolet
Silverado LD
2014
2014
L83, L86
5.3 and 6.2L Engines
GMC
Sierra LD
Involved vehicles are identified on the Applicable Warranties section in GM Global Warranty Management system. This site should always be checked to confirm vehicle involvement prior to beginning any required inspections and/or repairs.
Condition:
Some 2014 model year Chevrolet Silverado LD and GMC Sierra LD vehicles equipped with 5.3L or 6.2L engines (RPO L83 or L86), may have a condition in which the cycling of the thermostat may result in stress fractures on the radiator, and may lead to coolant leaks.
Special Coverage Adjustment
This special coverage covers the condition described above for a period of 5 years or 100,000 miles (160,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after November 15, 2016, are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to November 15, 2016, must be submitted to the Service Contract provider.
Correction
Dealers are to install a new thermostat and if necessary, replace the radiator. The repairs will be made at no charge to the customer.
Parts Information
Quantity
Part Name
Part No.
Radiator
84062175
Water Pump Outlet (w/Thermostat)
12674639
3
Transmission Fluid Cooler Pipe Retainer
24205103
3
Engine Coolant
12346290 (US)
10953464 (Canada)
Note: Use the vehicle identification number (VIN) and the GM Electronic Parts Catalog (EPC) to determine which part to order.
Warranty Information
Labor Code
Description
Labor Time
Trans. Type
list distribution/regions,if applicable]Net Item
9900393
Diagnostic Time Only – No Repair Required
0.1-0.3
ZREG
N/A
9900394
Replace Radiator and Engine Coolant Thermostat Housing
Add: Diagnostic Time
2.9
0.1-0.3
ZREG
N/A
9900395
Customer Reimbursement Approved - For USA and Canada dealers only
N/A
ZREG
9900396
Customer Reimbursement Denied – For USA dealers only
N/A
ZREG
* For USA and Canada: Submit the dollar amount reimbursed to the customer in Net/Reimbursement. Submit $20.00 administrative allowance in Net/Admin Allowance.
** Submit $10.00 administrative allowance in Net/Admin Allowance.
Service Procedure
Note: For this particular condition, signs of leaks can be found where the radiator tubes attach to the radiator headers.
  1. Verify that the radiator is leaking. Refer to Cooling System Leak Testing (L83, L86, LV1, LV3) in SI.
    • If the radiator is NOT leaking, no further action is required. Inform the customer that any additional diagnosis and repairs are not covered under this special coverage.
    • If the radiator is leaking, replace the radiator and the engine coolant thermostat. Refer to Radiator Replacement (L83, L86) and Engine Coolant Thermostat Housing Replacement (LV1, LV3, L83 with Thermostat) in SI.
Customer Notification
General Motors will notify customers of this special coverage on their vehicle (see copy of typical customer letter included with this bulletin).
Customer requests for reimbursement of previously paid repairs to correct the condition described in this bulletin are to be submitted to the dealer prior to or by November 30, 2017. See General Motors Service Policies and Procedures Manual, Sections 1.4 and 6.1.10, for courtesy transportation program details.
November 2016
This notice applies to your vehicle, VIN:_____________________________________
Dear General Motors Customer:
As the owner of a 2014 model year Chevrolet Silverado LD or GMC Sierra LD, your satisfaction with our product is very important to us
TThis letter is intended to make you aware that some 2014 model year Chevrolet Silverado LD and GMC Sierra LD vehicles equipped with a 5.3L or 6.2L engine, may have a condition in which the cycling of the thermostat may result in stress fractures on the radiator, and may lead to coolant leaks.
Do not take your vehicle to your GM dealer as a result of this letter unless you believe that your vehicle has the condition as described above.
What We Have Done: General Motors is providing owners with additional protection for the condition described above. If this condition occurs on your 2014 model year Chevrolet Silverado LD or GMC Sierra LD within 5 years of the date your vehicle was originally placed in service or 100,000 miles (160,000 km), whichever occurs first, the condition will be repaired for you at no charge. Diagnosis or repair for conditions other than the condition described above is not covered under this special coverage program.
What You Should Do: If you believe that your vehicle has the condition described above, repairs and adjustments qualifying under this special coverage must be performed by a General Motors dealer. You may want to contact your GM dealer to find out how long they will need to have your vehicle so that you may schedule the appointment at a time that is convenient for you. This will also allow your dealer to order parts if they are not already in stock. Keep this letter with your other important glove box literature for future reference.
Reimbursement: If you have paid for repairs for the condition described in this letter, please complete the enclosed reimbursement form and present it to your dealer with all required documents. Working with your dealer will expedite your request, however, if this is not convenient, you may mail the completed reimbursement form and all required documents to Reimbursement Department, PO Box 33170, Detroit, MI 48232-5170. The completed form and required documents must be presented to your dealer or received by the Reimbursement Department by November 30, 2017, unless state law specifies a longer reimbursement period.
If you have any questions or need any assistance, just contact your dealer or the appropriate Customer Assistance Center at the number listed below.
Division
Number
Text Telephones (TTY)
Chevrolet
1-800-630-2438
1-800-833-2438
GMC
1–866–996–9463
1–800–462–8583
Puerto Rico – English
1-800-496-9992
Puerto Rico – Español
1-800-496-9993
Virgin Islands
1-800-496-9994
We are sorry for any inconvenience you may experience; however, we have taken this action in the interest of your continued satisfaction with our products.
Terry M. Inch
Executive Director
Global Connected Customer Experience
Enclosure
15829
#PI1513A: Coolant Smell and/or Slight Leak at Radiator - (Nov 15, 2016)
Subject: Coolant Smell and/or Slight Leak at Radiator
999999995.gif Models: 2015 Cadillac Escalade Models 2015 Chevrolet Silverado, Suburban, Tahoe 2015 GMC Sierra, Sierra Denali, Yukon Models, Yukon Denali Models Equipped with 4.3L, 5.3L or 6.2L Engine (RPOs LV1, LV3, L83 or L86)
Attention: This PI also applies to any of the above models that may be Export from North America vehicles.
This PI has been revised to remove the 2014 Model Year and update the Parts and Warranty Information. Please discard PI1513.
Condition/Concern
Some customers may comment that they may smell coolant while driving or outside the truck. This could include a coolant leak under the front of the truck.
Recommendation/Instructions
Technicians should start by inspecting the radiator for signs of leaks. Normally, signs of leaks can be found where the tubes attach to the headers.
This condition may be the result of excessive thermocycles within the cooling system caused by excessive cycling of the thermostat. These excessive thermocycles within the coolant system may cause the tubes to fatigue, crack and leak at the radiator headers. To correct this condition, a new thermostat has been designed that eliminates the thermostats excessive cycling.
If this condition is found, in addition to replacing the radiator, the engine coolant thermostat housing (w/thermostat) must also be replaced. Refer to Engine Coolant Thermostat Housing Replacement in SI, which is located in the Engine Heating and Cooling section.
Parts Information
Part Number
Description
Qty
84062175
RADIATOR ASM
OUTLET, W/PMP (W/THERM)
RETAINER, TRANS FLUID CLR PIPE FTG
3
12346290 (US)
10953464 (Canada)
ENGINE COOLANT
3
For vehicles repaired under the Powertrain coverage, use the following labor operation. Reference the Applicable Warranties section of Investigate Vehicle History (IVH) for coverage information.
Labor Operation
Description
Labor Time
4080838*
Replace Radiator and Thermostat
2.9 hrs
Add
Diagnostic Time
0.3 hr
*This is a unique Labor Operation for Bulletin use only.
Additional Keywords: Odor
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Thanks!!
So the thermostat is to be replaced on all trucks that have received letters, and if leaking the radiator as well? Am I reading that correctly?
Yes you are reading that correctly. A new thermostat will be installed as to eliminate the cycling that is causing the problem.
Interesting, I was just at the dealer yesterday as my thermostat housing had cracked and it drained out 2/3rds of my coolant. They never mentioned that, they fixed the thermostat and its connections and refilled my coolant. I was up in Maine for the holiday weekend so it wasn't my normal dealer, but I will check with the dealer in NH where I bought the truck and see what they know of this.
