1500 upgrade
Tangle
I have a 01 k1500 and was wanting to know if you can put k2500 upper and lower control arms to swap knuckle for 8 lug wheel patter also wanting to know if my cv shaft will work with 2500 wheel bearings I have a donor truck with messed up frame and swapping out motor transmission and rear axel to my truck or if any one has done this or ran into problems and help would be much appreciated
What they may wear out faster would be the wheel bearings. But, as long as you don't get adapters with a huge thickness (maybe 1"-1 1/2") then it won't be any different than getting low offset rims that stick out. At least that's what I figure.
I don't think they'll fit anyways. Is your front differential the same gear ratio though as this new rear axle? If not many many problems ahead of you if you go through with install.
Sent from my Z981 using Tapatalk
    247.7k
    2.6m
    Jason Coe
    Jason Coe
  • Who's Online   4 Members, 0 Anonymous, 913 Guests (See full list)
