  • 0
PCM not sending 12v to crank sensor
Brownman863
Question
Working on a ups truck with a 2014 gm 6.0 with a E78 PCM ,no power ,backfiring into intake on acceleration,codes p0174 and p0171,while testing found that the PCM is not sending 12v to the crank sensor.replaced PCM and same problem,I'm testing at the PCM so I'm assuming the wiring to the sensor is good,I can jump 12v to the sensor and the fuel trims zero out .the funny thing is that the PCM puts out a steady 5v to the sensor not 9 not 4 but 5v?any ideas
4 answers to this question
GM sensors almost always run on 5v. I may even go out on a limb and say they all run at 5v. P0171 and 174 are lean codes and that would be further evidenced by the backfiring. not sure what you have going on but check the fuel pressure.
