Need Advice on New Van
I am going to be ordering a 2004 GMC Savana within the next 2 weeks and really need some advice. I am a locksmith, that puts 25,000 miles per year on a vehicle and and carries a shop with me everywhere i go. About 2000 lbs of it. I am pretty set on getting a 2004 Savana 2500 6.0 8600 GVWR with a curb weight of 5236 that leaves 3364 for a payload I figure 2000 lbs equipment 200 lbs of fuel and 200 lb driver that leaves almos t 1000 lbs left. Will that be overworking the susp. or ok with room to spare. I would rather have the above than a 1 ton because it weighs almost 300 lbs pounds less empty and gas mileage is a concern. Also the brakes on the 8600 and the 1 ton are the same so I guess the susp. is 300 lbs heavier on the 3500 w 9600 GVWR. Also What rear end do you guys recommend 3.73 or 4.10, most of my driving is around town @40mph but I do have a lot of 20 to 50 mile trips @70mph. I think that the 4.10 may help around town but may kill the highway mileage. TOW HAUL BUTTON?????? The estmate I got was 12/16 for the 6.0 in a Savana didn't say 2500 or 3500 3.73 or 4.10. What can I expect to get from day to day. What is up with this csk thing has been corrected or not?? Some say there was a change in the 03' model year but some people with o3s have this problem???????? Thanks in advance and sorry for such a long post.
to save gas on the highway the 3.73 would be the best bet, but the 4.10 will have more tire roasting off the line power. The engine is pretty strong and I don't think you would have to worry. If the tranny is shifting around a lot hunting for gears, keep it in 3. If it feels like you can't get up the interstate merge ramp fast enough, use the tow/haul button. It will keep it in gear longer hitting higher rpms.
