laminarflow Posted August 31, 2016 Share Posted August 31, 2016 Didn't know that Fluid Film will soften the wax. That said, it's not petroleum based and therefore is safe to use around rubber and plastics. It's great for places you can't reach like inside the frame, inside doors, etc. I find the wax chips easily ... probably even more so in winter. Link to comment Share on other sites More sharing options...
Rkaroll953 Posted August 31, 2016 Share Posted August 31, 2016 the Daubert stuff is the brand of wax on the frame? Link to comment Share on other sites More sharing options...
jamoka3 Posted August 31, 2016 Share Posted August 31, 2016 I heard that Fluid Film is still best, to use even tho it makes the wax soft, just have to re-apply it yearly. Its bad when the wax gets hard cause then it chips off... Chevy /GM wax is really only there for assembly of the trucks to keep the frames nice, and is not intended to last more then a year off the assembly line. (Nielsen Chevy , mechanic told me this information...) Link to comment Share on other sites More sharing options...
Colossus Posted August 31, 2016 Share Posted August 31, 2016 Based on that link, it looks like Ford is using the same crap? I use fluid film on my boat and waverunners, works great until I have work on it... which is extremely rare but it keeps the rust off everything, haven't tried it on with our wax coating on our trucks. I my last Denali the factory wax was so dry it would fall in pieces in my driveway, rust to primer paint, wait to dry then add the 3M under body coating and its held up grade for the past 2 years but I am TX. like the others above stated, GM is using https://www.daubertchemical.com/ Link to comment Share on other sites More sharing options...
camcamaro1991 Posted August 31, 2016 Share Posted August 31, 2016 the Daubert stuff is the brand of wax on the frame? Yes sir, it should be the same soft black wax coating but it will apply thinner from the can vs dipped at the factory, I like it but it does come off easy, get rust to primer paint, then wax it. Based on that link, it looks like Ford is using the same crap? same company but different product GM = Nox-Rust®X121B ------------------------------------------ GM part#12346501 not a good part number anymore GM Technical Service Bulletins PI-0564D and 14002 Nox-Rust® X-121B (also known as "Nox-Rust® X-121 Black") dries to a firm wax-like film that will repel water, self-heal, and remain flexible at low temperatures. Can be easily applied using low-pressure airless equipment. Ford = 7703-W (Ford did use x121b in the past) Ford Technical Service Bulletins 15S14 and 14S22 A low color, translucent rustproofing compound with a thin gel, but low viscosity. This allows for film builds on vertical surfaces and for seam penetrations (capillary action) into areas with metal-to-metal overlap. The resulting film is wax-like in nature and will repel water, self-heal and remain flexible at low temperatures. Dry time is 4 hours to touch and overnight for full cure http://www.gm-trucks.com/forums/topic/145254-my-2500hd-fully-detailed-top-to-bottom/ Link to comment Share on other sites More sharing options...
Rkaroll953 Posted August 31, 2016 Share Posted August 31, 2016 wheres the best place you guys have been finding the dauber frame wax stuff. looks like it comes in a 1 quart can to brush on. Link to comment Share on other sites More sharing options...
camcamaro1991 Posted August 31, 2016 Share Posted August 31, 2016 wheres the best place you guys have been finding the dauber frame wax stuff. looks like it comes in a 1 quart can to brush on. I just ordered a case of 12 cans off the Daubert website "$131ish shipped & taxed", I will let you know when I get it, I need to touch up some spots of when rubbed off some areas when I added my GM Borla exhaust and front off road plates. https://www.daubertchemical.com/store/product-list/corrosion-prevention/nox-rust-x-121b NOX-RUST® X-121B Nox-Rust® X-121B (also known as "Nox-Rust® X-121 Black") dries to a firm wax-like film that will repel water, self-heal, and remain flexible at low temperatures. Can be easily applied using low-pressure airless equipment. AVAILABLE SIZES 1 Aerosol Can Estimated coverage, 7 to 10 square feet per can. $14.99 ADD TO CART Case 12 Aerosol Cans - Estimated coverage 7 to 10 sqft. per can $107.23 ADD TO CART 5-Gallon Pail $184.85 ADD TO CART MORE INFOTo learn more about this product including related documents and demos, click here. Link to comment Share on other sites More sharing options...
500sks Posted September 1, 2016 Share Posted September 1, 2016 Here is a pic of the can Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
Rkaroll953 Posted September 1, 2016 Share Posted September 1, 2016 sweet just what i was looking for. im gonna go crazy with this stuff and fluid film before the snow! Also thinking about re painting my rear end. its already starting to rust and i dont wanna let it get out of hand. Link to comment Share on other sites More sharing options...
jamoka3 Posted September 1, 2016 Share Posted September 1, 2016 Amazon has this on there site, made by Daubert, wonder if its any good? https://www.amazon.com/Daubert-Cromwell-NR3100AEROSOL-Corrosion-Inhibitor/dp/B00AYN8S3Y/ref=sr_1_fkmr1_1?s=industrial&ie=UTF8&qid=1472731039&sr=1-1-fkmr1&keywords=Nox-Rust%C2%AE+X-121B Link to comment Share on other sites More sharing options...
camcamaro1991 Posted September 1, 2016 Share Posted September 1, 2016 Amazon has this on there site, made by Daubert, wonder if its any good? https://www.amazon.com/Daubert-Cromwell-NR3100AEROSOL-Corrosion-Inhibitor/dp/B00AYN8S3Y/ref=sr_1_fkmr1_1?s=industrial&ie=UTF8&qid=1472731039&sr=1-1-fkmr1&keywords=Nox-Rust%C2%AE+X-121B jamoka3, that's not the same product. its a Daubert product for sure but its 3100 not X121B 3100 = The dry film is firm, amber/translucent and when applied to the recommended dry film thickness, will protect ferrous and non-ferrous metals in protected or unprotected storage. It can be handled after 3-6 hours, and sets up in 12-24 hours. Nox-Rust 3100 can be removed Link to comment Share on other sites More sharing options...
sdeeter19555 Posted September 4, 2016 Share Posted September 4, 2016 From my understanding Fluid Film is simply wool wax, but since it comes in varying viscosities; it likely has a solvent in it. It worked well in the doors and the body on my truck, but caused sheets of the factory coating to shrivel and peel off to bare metal. I think all the the issues with the GM coating is surface prep...something on the frame during application is preventing proper adhesion. Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
sdeeter19555 Posted September 4, 2016 Share Posted September 4, 2016 I looked into Ziebart, and was told they only spray the wax on body parts, the frame gets a rubberized undercoating. I asked two different places and was told the same. Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
DPetry94 Posted September 18, 2016 Author Share Posted September 18, 2016 If someone uses the daubert stuff sometime soon let me know, I wanna hear from a few people before I get some maybe. Link to comment Share on other sites More sharing options...
camcamaro1991 Posted September 18, 2016 Share Posted September 18, 2016 If someone uses the daubert stuff sometime soon let me know, I wanna hear from a few people before I get some maybe. This is the product you want, the aerosol spray it has a little more gloss look. The factory machines that carry the frame down the assembly line will have 4 spots of frame that are un coated b/c the machine rubbed it off, plus anything thing else during assembly. let me see if can grab some pics. Link to comment Share on other sites More sharing options...
