WTT 04 GTO m6 for 03+ 4wd gm truck
Popwar8
Sorry for blurry pic
Looking to trade for an 03 and up Silverado/Sierra ext cab or crew cab , must be 4x4 . R title O.K if low low miles . Might be interested in other full size trucks as well. Also interested in Manual c5 vettes, cts-v , 03 up wrangler hard top with power windows and locks
Texas Speed 228r cam (.588/.588)
Texas Speed 7.40 push rods
COMPcams valve springs
Ported throttle body
Ported ls6 oil pump
AEM BruteForce CAI
Kooks headers
Kooks high flow cats
Magnaflow exhaust
Electric Exhaust cutouts
Voxx Maglia 18x8.5 wheels with yokohama tires
Powerstop drilled/slotted rotors and pads
Whiteline adjustable radius rod bushings
Whiteline endlinks
New Monroe front struts
New Monroe rear shocks
New Roadsafe tie rod ends from Kollar Racing
New strut top mounts
New Hood Struts from GTOG8TA
New driveshaft carrier bearing
M1 0w40 oil w/ wix filter
Dexron3 trans fluid
Torco rear diff fluid
B&M Short shifter
New thermostat
New timing chain
New gates serpentine belt
New water pump gaskets, crank bolt, timing cover gasket,crank seal etc
New reman ps pump
New reman steering rack
New oem PS pressure line
Drag bags in rear
Trans was rebuilt 4 years ago
1st gear synchro is slow , not a big deal . I have a video below showing a short drive and of slow synchro , plus dyno, and walkaround . My daily driver.
the TOB just started making noise . I have a new one to go with it.
Have receipts for everything . Thanks for looking .
http://tricities.craigslist.org/cto/5703317022.html
