Twin Turbo kit for 4.8 5.3 6.0
lancer
I'm selling a twin turbo kit for a 4.8, 5.3 or 6.0. Complete kit with everything needed. All oil lines and fittings were upgraded to steel braided. Was installed on truck for only a few minutes and only had one start up on it. My tuner talked me back into putting my supercharger back on for towing purposes. It's all boxed up and ready to go. My loss is your gain. $1000.00
It's a direct kit. Everything is plug and play. The only thing you need to do is have the truck tuned. There eBay turbos, my intentions were to get the truck dialed in then upgrade the internals in the turbo housings.
Is there instructions and this is for a 2015 Silverado 1500 with the 5.3?
Not to be a downer, but this is going to be for 99-07 classic V8s. Not the new Gen V GM V8s. You may be able to modify it to work, but it will not be a direct bolt on by any means. Just want to make sure you don't get stuck with something that doesn't work for you. :)
Correct. It's technically not applicable for the newer gen models. Like Josh_perry24 said it probably could work with some modification. I'm not sure if the exhaust manifolds are the same on my truck as they are on yours. That would be the biggest deal. Everything else should fit no issues.
Owned a 2001 and 2002 Silverado with the 5.3L and now have two Gen Vs. Can confirm, exhaust manifolds are different between the two.
  • 2 years later...
Where you located?
