yellow headlights
Hi all, Did the headlights on the 2000 s10. I sanded with wet sand paper till i got to 1400. lights had that white foggy look to them. I used blue magic head light lens sealer. That cleared them up some but not perfect. Should I use less grit paper? Will that help the haze? Say, 2000 and up? I've seen people use clear spay paint. Any one try that??
I'd start with P600 wet then P800 going to P1200 .... P2000 and last P3000 then buffing them with a foam pad and 3M # 06085 rubbing compound works better than any kit you can buy
on the 1st quick pass with the buffer you will be amazed at the lens , the 3M 6085 compound is real smooth with no real grit in it but it polishes great
Never used clear paint on any yet but if there is any discoloration still there after sanding the clear won't help to make it look any better
Clear paint / seaker will not make your headlights clear. They will only help preserve the yellow it is currently.
Your yellow problem couple also be on the inside if its more of a burn..
    247.7k
    2.6m
    Joe Upton
    Joe Upton
  • Who's Online   0 Members, 0 Anonymous, 635 Guests (See full list)
