AirLift for the HD
Im looking into the Airlift (superduty)for the rear of the HD. And wondering if anybody has run or know's anybody with one? Did it make a difference towing and in ride?
Thanks
I've got the SD setup in my truck. Works as advertised. :thumbs:
Money well spent. Got rid of the sag and the diving I'd get when cruising down the interstate. Rides much better when loaded- not as "soggy" as it was without the bags. Unloaded ride is unaffected when the air pressure is at 5 PSI.
:D
I have a set on my 03 2500HD D/A LB Ext Cab as well as a set on a 2K 2500 Silverado. I have a 9 1/2 ft Lance camper that weighs in at about 3000 lbs loaded. With 35 psi the truck is level, and the ride is great. If you routinely tow or have a camper I would also recommend a set of Rancho 9000s.
I think both trucks ride better than new with the shocks. I also keep about 10psi in the Airlifts; seems to add a bit of stability when the truck is empty.
They're pretty easy to install, took me about an hour and a half on my '03. Just make sure everything is in alignment before you tighten up the mounts. Also make sure that you use individual air lines to the Airlifts.
Mike
I have air springs on my HD and love it! Also have in-cab control. System uses all electric controls (no air in cab), digital gauge for tank and bag pressure. Sure beats airing the system up with a tire chuck!
:thumbs:
    247.6k
    2.6m
    Goat House
    Goat House
  • Who's Online   5 Members, 0 Anonymous, 812 Guests (See full list)
