JoeTsarukyan Posted June 16, 2016 Share Posted June 16, 2016 So I'm driving back from work about to exit, all of a sudden the truck downshifts hard to the point were my seatbelt tensed. The truck jerks, my check engine comes on, and afterwards I notice the truck is very sluggish, probably starting in 2nd gear. Took it in this morning, the guy calls me back saying it looks like it gave out transmission codes, so he's suppose to call me back with the full diagnosis... Now, my question is could me installing ltz projector headlights along with ddm tuning basic hid kit have ever caused this? I just don't want them to blame it on something like the headlights...there is no flicker with my headlights or anything like that, just one thing I noticed was that one of the bulbs turned off for a split second and came back on, I myself don't think I have anything to worry bout but who knows.. Link to comment Share on other sites More sharing options...
Britt Lifsey Posted June 16, 2016 Share Posted June 16, 2016 Absolutely possible. Have you towed with a non GM drawbar? Another possibility. Link to comment Share on other sites More sharing options...
TxTruckMan Posted June 16, 2016 Share Posted June 16, 2016 No way. Link to comment Share on other sites More sharing options...
JoeTsarukyan Posted June 17, 2016 Author Share Posted June 17, 2016 Haha, OK that's what I thought thanks. Link to comment Share on other sites More sharing options...
MOhunter92 Posted June 22, 2016 Share Posted June 22, 2016 On my 2006 Silverado I put a DDM tuning HID kit on it. Next day the truck went into limp mode on a windy 2 lane country road and engine light came on, truck wouldn't move. I shut it down, pulled the battery cable and turned it on and it was fine. Years later that kit ended up causing all kinds of havoc on the computer. It's very possible that it caused the issue. A relay harness helps prevent it Sent from my treestand using Tapatalk Link to comment Share on other sites More sharing options...
L86 All Terrain Posted June 22, 2016 Share Posted June 22, 2016 Headlights connected to transmission? If so im trading my truck in for a 98 silverado. Link to comment Share on other sites More sharing options...
MOhunter92 Posted June 23, 2016 Share Posted June 23, 2016 Headlights connected to transmission? If so im trading my truck in for a 98 silverado.No it's not "connected". If you read my post I had a 2006 Silverado, not even near the tech of his new generation. It makes the computer think power surging is going on and it freaked out and went into limp mode. Only did it one time and the truck became used to it. I'm willing to bet that's what happened with this truck, if nothing is wrong with it when it gets checked at the dealer. By not using a relay harness it is pulling a lot of power upon ignition from the factory bulb harness that it's not used to, as a result it can cause a problem. If the OP didn't try and reset the truck by disconnecting the battery and turning it on, this is probably the case. Because that's exactly what my 06 did Sent from my treestand using Tapatalk Link to comment Share on other sites More sharing options...
cbrsilv15 Posted June 23, 2016 Share Posted June 23, 2016 Sounds like a coincidence to me. Link to comment Share on other sites More sharing options...
