I have a 2003 Silverado 2500, that has the purple marked torsion keys installed from the factory. I'm looking to level the front end up a couple inches but I see a lot of red flags regarding the purple keys as far as purchasing new ones. I've been reading that I can level it up to 2" with the stock keys and getting longer shocks or the bracket. What are my options?? Thanks.
Just crank up your stock keys and see what happens. If you can get 2" out of them, then you don't need to waste your money on a set of aftermarket keys. I wouldn't go over 2.5" regardless of the method you use. And yes, it will ride rougher, but longer shocks or shock extensions will help a little bit.
