LED 9005 and 9006 bulbs. Question with poliarity.
Questions in regards to installing a set of drop in LED headlight bulbs.
We ordered a set of LED lights. They came with the transformers or drivers, etc. what ever they are called.
The lights have little cooling fans and were guaranteed for a long time.
I plugged them in and they did not work.
I tried on another vehicle and same results... nothing.
I received a replacement set.
I noticed the + & - on the connectors of the LED lights.
So I got out my multi meter and determined which truck lead was positive and which pone negative.
WEIRD, both trucks are opposite of the connector requires.
If I connect the new LED lights the "backwards" now they do not "SNAP" or "Lock", they WORK.
Has anyone came across a situation.
I guess the OEM lights do not require a specific positive and negative orientation.
Would it hurt any other system if I simply reverse the headlight wires.
This way I can use the LED lights and connect them and have the clips "Lock"
