0 or -12 offset?
Looking to get my tire to b just about flush to the outside of my fender or maybe a 1/2" past. Im mounting 285/75/18's on my 2500, which offset will get me closest to what im looking for. Plus if your truck has 18x9's with the offsets im asking about post a pic looking down the side. Thanks all
  • Replies 44
  • 2 months later...
I just purchased a set of anthem rims 18x9 with a zero offset and wrapping them in 285/75/18 toyo at 2 extreams. They are 35x11.6 inch tires and should fill the wheel well perfectly.
Pics?
I did have just alittle rub but it was bc of the 35 inch tire. If u went with a 34 inch tire you should clear no problem.
Your truck looks awesome! That's a great tire size for these HD's (along with 295/70/18). Have you noticed much of a MPG hit? Also, what are your suspension mods again?
Thanks man! Your truck is the reason i went with this size lol. Wanted the height without so much of the width. My MPG went down about 1-1.5, nothing major. As far as the suspension I should have listened to you guys. I went with a kit that put 3 inchs in the front and 1 in the back. Looked awesome and rode really good. Once I got the new tires on it looked exactly the way I wanted, it was perfect but I noticed it was a rougher ride and it had a lot of bump steer. I couldn't take the bump steer issue and relized it was bc of bad geometry of the front end. In the end i ended up dropping the front end down to around 2 1/2 inchs, cleared everything up and drives decent again. Trimmed just a tiny bit of plastic but that was all.
