- 0
08 Yukon Starting Issue When Hot
Similar Content
- 8 replies
- 922 views
- 5 replies
- 1,348 views
- 17 replies
- 1,927 views
- 0 replies
- 2,749 views
- 0 replies
- 1,363 views
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 9 Members, 1 Anonymous, 2,166 Guests (See full list)
Question
Lever23
I have a 2008 Yukon (5.3L V8, Flexfuel) that's having some starting issues after running for an extended period of time. Engine turns over fine when cold, but after driving for an extended period of time (minimum 30mins, varying speeds - city, highway), shutting the engine down and restarting after 10-30mins the vehicle starts funny.
Instead of cranking over normally, it fires up almost immediately after turning the key - maybe half a crank. Engine then revs high for 5-10 seconds before returning to normal RPM. I've had the fuel pressure system tested and it came in at 55psi. I've also started monitoring if the issue pops up as the fuel level in tank decreases.
I'm wondering if the Fuel Pressure Regulator on the engine block or on the tank could still be causing an issue like this? Or if the Fuel Injection System might have an issue? Any other suggestions would be greatly appreciated. Thanks!
2 answers to this question
