6.2 Dyno with Common Bolt-ons
  • 7 months later...
What made you decide to go with 1 3/4 vs 1 7/8 headers. Thanks for posting the dyno numbers, wish I could see a comparison to a set of 1 7/8 I'm trying to decide what to go with for my other wise stock 2011 6.2 I am running a black bear tune
Edited by Crobinson16
  • 1 month later...
I wish there was someone near St. Louis that did dyno tuning like this. I'd love to tune my truck but don't want it done remotely based off of what my parameters "should" be running at.
I know you posted this a while back....If you would like to pm me I should be able to get you a couple names of people locally that can potentially help you if your still interested.
There isn't much difference with the two, the 1 3/4 will give a little bit more low/mid range which is what I would consider more usable with this application (truck).....if this were a car with an LS powered 6.2 like a corvette or camaro it would be 1 7/8 every time as there isn't enough of a difference not to take advantage of the few extra hp/tq in the mid/upper rpm's.
As long as you don't tell me Shane Hinds or PBJ I'm all ears.
I hear ya there!!
Dave Steck did all my tuning in the past, I'm sure your aware that he moved to TX but I know he offers remote tuning as long as the person has access to HP Tuners or knows someone that does.
There is a local guy named Jake Batz that is a bit of an unknown, he is good with NA applications but I'm not sure if he has the experience with tuning transmissions?
I will reach out to him to see what he says and let you know.
Have a great 4th!
I hear ya there!!
Have a great 4th!
I had Dave tune my last couple trucks, and he's tuned umpteen of my friends' drag cars. What a bummer when he moved, but man was I glad to hear that he's starting tuning for us peasants again. Dude is like a wizard. I've actually heard a little about Jake. Shoot me a pm when you hear back from him. Thanks!
Better results than I expected, congrats! I'll be doing the same to mine hopefully this winter.
- Stock wheels / tires: On a 2WD street truck changing from 20's to 24's I saw a friends truck drop 30whp on back to back pulls last November, however that was on a 5.3 with same mods as yours w/E85. I'd think your 20x10's & 34's are likely costing you 15-20whp.
- Regarding a post above referencing E85, the 6.2's don't have as high a CR as the 5.3's so the gains won't be as much which explains why GM doesn't have an E85 tune loaded. With a belt driven intake manifold, E85 would deliver the goods !
  • 9 months later...
False, the 6.2 has a higher compression ratio for sure
its either half a point or a full point higher
You are correct, since I posted that July last year I learned the 6.2 is a half point higher at 11.5:1.
I'm curious as to why the 5.3 is rated from GM to produce more power with E85 and the 6.2 is not (especially with the higher CR).
The 6.2 is not e85 compatible from the factory. That’s probably why it’s not rated higher with e85.
    247.7k
    2.6m
    Semyon Glinkin
    Semyon Glinkin
  • Who's Online   4 Members, 0 Anonymous, 495 Guests (See full list)
