level with 285/75r17
I just got  285/75-17 Toyo MTs mounted on 17x8.5 0 method grids. I have the eibach pro truck levling kit set at 2.5 inches in the front and kryptonite UCAs. Nothing done to the back. I had to trim the fender liners a good amount but it now drives without rubbing at all on the street. No metal trimming. It is very close to the plastic cap covering the cab corners but clears. The Toyos run big as well. If you are getting an AT you will definitely be able to fit with less trimming if you have a 2.5 inch level. I think the 0 offset played a big role in fitment as well. Stock wheels with alot of positive offset it will rub like crazy on the inside liner/components and negative offset will rub on the cab corner.
  • 3 months later...
Can confirm, AT in a 285/75r17 fits with no rubbing!
