- 0
2008 Chevrolet 1500 Silverado WT 4.3L V6 won't turn over or start
Similar Content
- 4 replies
- 5,934 views
- 19 replies
- 3,076 views
- 3 replies
- 1,382 views
- 3 replies
- 6,943 views
- 1 reply
- 3,321 views
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 7 Members, 1 Anonymous, 1,680 Guests (See full list)
Question
ChevDev
I just recently parked my Chevy 1500 Silverado WT to do some routine work. when I attempted to start it up all that happened was the key turned and the instrument panel lights went out and there was an audible click from that area. I got out and check the battery connections, battery (which is fairly new) and the starter relay on the fuse block. I even tried jumping it off of a running vehicle, but still the same problem exist. All the lights and radio work fine so I assume the battery is not the cause for the sudden death. I tried swapping the starter relay with another relay (one that was for fog lights which I don't have) and I still get the same response. I then took out the ignition relay fuse and found the power side and connected it to the ground terminal and nothing happened. I repeated the same steps on the starter relay and I heard the starter click. I have never had any starting problems (with the exception of the key getting stuck from time to time) with the truck or any kind of work done recently. I don't have a anti-theft system as far as I know. Since I'm sure the problem is electrical in nature could anyone tell me what could be the cause or what I should investigate next? I understand there could be many failures in the system that could cause this, so I will try and seek out the most likely causes first. Hopefully I can avoid having to tow it to the dealer for a diagnosis and repair with the help of a knowledgeable and friendly mechanic.
Thanks in advanced for anyone who can help me.
7 answers to this question
