No Cutting Lift Kit to fit 33's
2015Z71
You can run a 2 inch level in the front and a 0 offset wheel. That will allow you to run 33x12.50 without any cutting.
I have this setup but it rubs a little when turning. I don't feel it going forward, but it is more noticeable in reverse. I have 0 offset 20" gear alloy big blocks with 33x12.50 toyo at2 extremes.
sent from my Samsung Galaxy S6
Edited by dkweeks
  • 10 months later...
2-1/2" RC Level Kit, 20x9 OE Wheels, 305/55R-20(basically 33-12.50) Nitto G2's. No cutting
Where did you get your rims and how are they quality wise ?
I found this same set of wheels at a shop called Novus Wheels in Texas, i love the look of them but im skeptical on the quality cause they're a replicas.
Please let me know, it would help me so much !
I am running 305/55R20 Nitto terra grapplers with a stick set up and they only rub at full lock... I am adding bolstering 5100's at the highest setting and should clear them with no rubbing once complete
  • 3 years later...
