Wingnut Posted April 19, 2003 Share Posted April 19, 2003 Trucktrend Even gives nods to americanmusclemans guy up there in Tulsa. (Ed Wright of fastchip.com) Link to comment Share on other sites More sharing options...
TROYROBO Posted April 20, 2003 Share Posted April 20, 2003 :thumb: :thumb: Link to comment Share on other sites More sharing options...
cowboy02 Posted April 21, 2003 Share Posted April 21, 2003 Link to comment Share on other sites More sharing options...
CMNTMXR81 Posted April 21, 2003 Share Posted April 21, 2003 Trucktrend Even gives nods to americanmusclemans guy up there in Tulsa. (Ed Wright of fastchip.com) You mean, Ed Wrong at slowchip? Sorry, I as well as many people I know personally have had serious tuning problems with him. After 4 attempts to tune my PCM, he still couldn't get it right despite numerous a-tap logs, dyno sheets, A/F readouts, etc, etc. Then when you get him on the phone, he talks down to you. So I took my business elsewhere. Mind you, this was before LS1Edit was on the market, so there wasn't a lot of local choices for tuning available. Only mail order. As for the Blazer, kick arse!! Link to comment Share on other sites More sharing options...
americanmuscleman Posted April 21, 2003 Share Posted April 21, 2003 Trucktrend Even gives nods to americanmusclemans guy up there in Tulsa. (Ed Wright of fastchip.com) Awesome blazer! I bet that truck moves with 10lbs of boost! Like I've said before, I've had good luck with Ed. He's dyno tuned my friends cars, and they love it. For example, a friend with an 01' SS M6 with only a Thunder Racing 230/224 cam (and associated valvetrain), Mac midlength headers, catback and cold air... put down 397rwhp and 380rwtq with Ed's dyno tune (stock heads, and everything else stock). I've known quite a few other guys who have had great success with his tuning as well, but its all been dyno tuned. I've heard from other people that Ed's an A-hole, but the two times I've talked to him, he's been nice. Sorry to hear about bad luck you've had CMNTMXR81 Link to comment Share on other sites More sharing options...
CMNTMXR81 Posted April 22, 2003 Share Posted April 22, 2003 It wouldn't bother me if he were an A-hole is he'd have tuned it right! The difference between you and I is that you were obviously able to have him tune it on the dyno whereas mine was done via FedEx at $65 each time I sent the F*cking thing. They called me once when they had an opening, but I just can't up and leave Chicago to head to Tulsa. Now, the first time, I could excuse because it's a crapshoot and then you adjust from there. But each time I sent it to him, I sent A-tap logs, dyno sheets, and A/F readings from the dyno's. I didn't expect him to be perfect and right on the money, but pretty darn close. Instead, he turned off my EGR, even though he asked me if I had an LS6 intake which at the time I DIDN'T. So my car simply ran like chit around town and I was having major detonation from around 2,800 - 3,500rpm. Enough so, it #### near shut the motor down. So I went to Steve Cole at TTS. Same info that I gave Ed, I gave Steve, he sent me his powerloader, and that's what I've had since. His programming isn't a direct hit either for the same reasons Ed's wasn't expected to be, but even with his Mail order tuning, I still managed 398rwhp from my rather conservative setup (by today's standards for Heads and Cammed LS1's). The only negative I have to say about Steve Cole is that he locked my PCM. Meaning that we could not get into his program via LS1Edit to alter things last time I had it at Speed Inc. so I had to go get another PCM. On May 5th, it will be on the dyno at Speed Inc. for tuning. I know right now it's running too rich at WOT. From about 5,000rpm up it was running in the 12.5 - 12.0 range when it should be in the 12.8 - 13.1 range. I expect with this custom tuning, I should eclipse the 400 mark easily. I can tell you about 5 people I know personally both with LT1's (which seemed to be Ed's strong point) as well as LS1's that have had terrible tuning with him. Link to comment Share on other sites More sharing options...
