Paint Bumpers - vinyl wrap or plasti dip?
Was your truck an AT?
It is not. I originally planned to get the bumpers painted/powder coated, but there was just too much work required in removing bumpers and stripping them down.
  • Replies 64
Id like to wrap my bumpers on my bronze metallic GMC but I probably couldn't match that color.
would definitely be hard. I'd try calling a few of the local vinyl shops to see if any could print something for you to match it. I see you are from Lafayette, I can see if my buddy back in New Orleans can do it (he manages a vinyl/sign shop)
Yeah see what he says. This is something I would do myself just need the vinyl. But also if it crazy expensive then I just suffer with chrome.
What kind of prep did you do to your grill? What paint did you use? Did you use primer?
I scuffed mine with 320 grit sand paper and tried it with and without primer. I used summit white paint in a spray can from nappa. The paint comes right off if I run my finger nail over it. I dont see how it will last when I go to scrub bugs off.
Should I try and sand blast the the chrome of first? Should I used krylon fushin for plastic?
I wanted to get the grill wrapped but the one guy I took it to said it wouldnt stick because of the hard corners.
I did not personally paint the grill, that was handled by a body shop. You might see what they will charge if you remove the grill yourself, that's what I did.
Hows it holding up? If you run your finger nail over it will the paint come off?
  • 3 months later...
I want to color match my bumpers. My truck is 'white diamond'...has anybody found a wrap that matches that color well or should I just plastic dip / paint them? I found some 'white pearlescent' on Amazon but not sure how well it will match my paint.
  • 1 month later...
I want to color match my bumpers and grill surround. My truck is Slate Gray Metallic. What's the best way to do it? Can I find plasti ditto match my truck color?
  • 1 month later...
Paint on mines.
7FF29D52-3C81-4DD2-A1AB-79B4F906B8C9_zps
E66D61D3-75BD-4B84-B571-86548EBF792C_zps
Did you paint over the chrome? If so how's it holding up? Also what offset are your tires with the fender flares? Nice truck man!
Thanks, wheels are +24 with spacers on the rear.
So far so good holding paint, few rock chips here and there but I take a road often that's under constructions and the stupid dump trucks full of gravel are everywhere
Updated
D45B750C-F285-4AE3-9711-066973378D9B_zps
Updated
How difficult was the trimming for the quad fog light setup? That's next on my list
