i have a 1999 gmc sierra 2500 6.0 made in 1998 but has the 2000 round body style and newer motor from 2000's
i was adding my AUX and checking on my radio wiring and i forgot to drop my steering wheel down to let the dash cover fit through and i broke off my hazard light switch.
i found a blog post i thought would work(havent tried it yet) but wanna make sure. the part she said to get doesnt match up with my truck on autozone or amazon catalog thing.
blog post - http://sarahjoaustin.com/2010/01/15/how-to-repair-your-gm-hazard-light-switch/
is there anyway i can just buy the switch or do i have to rip my steering colum apart and replace my whole blinker arm?
any help would be much appreciated since im 19 and have no money due to my $8 an hour job and my 11 month old son
but i do know my way around automotive mechanics and tools
thanks
The link you provided is to a part prior to your year and as you have stated, it does not fit. You are actually looking for the button, which you call a switch. But the button is not a separate piece like the prior years, so the switch and blinker arm are one in the same. The link below is for a part hopefully you can handle within your budget, maybe someone can find a solution more economical than the link. I remember when I was 19.
Another option is to check your local junkyards for maybe the "button" piece or the entire switch.
http://www.discountbodyparts.com/catalog/feeds/GMC/Sierra_2500/Replacement/Turn%20Signal%20Switch/1999/ARBC505811.html?dbpcid=productads&c_dev=c&c_aid=53600227822&c_net=g&c2cid=561ec63d-5fad-45d9-a089-a8a882bc0ead
