Aux trans cooler upgrade, thickness..is bigger better?
I am going to upgrade my stock aux cooler here soon. Yesterday in 96* heat my trans temp reached 190. I don't tow or haul many heavy loads often but I just want the temps a little cooler.
I know most everybody is going to say to go with the TruCool 40K but I'm not looking to spend that much. I've narrowed it down to the B&M, Hayden or DeRale. All are 11" long and range from 7 1/2 to 9 1/2" tall. I'm going with that size for ease of fit so I don't have to cut/notch any supports. My question is on width. The B&M (# 70264, 14400 BTU) is 1.5" thick, the DeRale 9 row & 13 row, 9000 series (17500 GVW and 22000 GVW respectively) is 1.25" thick and the Hayden 678 is 3/4" thick.
Is it better to get a thicker or thinner cooler? I thought I read that the 3/4" is better because it dissipates heat quicker than the thicker models.
  • 3 weeks later...
After seeing this thread I decided to look at mine today. It hit 190 in maybe 95 degree GA heat, cruising down the road at about 40mph after only driving for maybe 10 minutes.
Never really paid much attention to it except when towing. Can't imagine 190 is considered high though.
Definitely considering an auxiliary cooler myself.
I went thicker but it is not necessary. My cooler is overkill, but i live in a warm area and was towing on a regular basis. My prior cooler was a B&M that was 11x8x0.75. But once again i live in an area that hits 100 almost daily in summer, in winter i overcool the fluid and it doesnt even hit 110°.
So, did some more observing this morning. Was running right around 190, in 72 degree ambient temps. Seems to get up to that point and then hang out, almost as though it's thermostatically controlled like coolant. Not sure if that's the case of not, but once it hit 190 it dropped back to 188 or so, and then came back up.
Seems to want to be at 190. Probably the optimum operating temperature for the fluid.
Update: 99 degrees this afternoon. Trans temps running between 187 and 192.
The transmission lines run to the radiator so it will run at the same temp as your radiator. This is typical of all GM cars and trucks except HD and larger trucks that are built for pulling.
I would suggest the Derale with a fan that is thermostatically controlled. I have seen the kits on their website and on Amazon.
