- 0
2006 Silverado Alignment Issue
Similar Content
- 3 replies
- 817 views
- 0 replies
- 2,600 views
- 0 replies
- 3,526 views
- 6 replies
- 3,771 views
- 4 replies
- 23,660 views
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 11 Members, 2 Anonymous, 1,316 Guests (See full list)
Question
JimH77
I have a 2006 Silverado 1500 - CrewCab - 4WD - 5.3L engine. The truck has never been wrecked and alignment prior to the work - was fine.
I had the following replaced due to age and wear indications: Upper and Lower Control Arm Bushings (with Poly), Sway bar Bushing (poly), Upper and Lower Ball Joints, Shocks, Tie Rods and Ends (i.e. entire assembly), Pitman arm, and Idler arm and Bracket (i.e. the pivoting assembly).
Took the truck in for alignment - and basically while everything appears fine and aligned without issue - the steering wheel is about 45 degrees to the right. The alignment people stated that the pitman arm was probably mis-aligned and they could not straighton the steering wheel without bottoming out the tie-rod on one side and that this would not be good.
So took the truck back and had the pitman arm alignment checked - it was fine - even had the old one re-installed to check things and there was no difference (i.e. the new one was not keyed wrong or mis-aligned).
Everything has been double checked and still the alignment of the steering wheel is off.
Verified that the part numbers used were correct and that there was no "difference between 2wd and 4wd or in the various years.
SideNote: the steering shaft was NOT disconnected to check the pitman arm.
Comments or thoughts?
8 answers to this question
