Npc246 to npc241 manual transfercase
I have two trucks one with auto push button and one full truck with manual 4wd ,well it work to take transmission and transfercase from manual T/C and install to my other truck using the computer and hooking a switch to activate the front diff acutor both 2004gmc,also I have plow truck 2500 series with 4l80e is this a direct swap and bolt replacement to a 1500 series truck as well meaning full transfercase and transmission thanks
Sure if you a clue or 743, frt diff actuator is controlled by the TCCM Ya know , a switch may not be that simple unless a close look at the schematic is done
Crazy attempt thou IMO
You should pass on doin it
