Leafspring Questons
Same u bolts should work if you have 4wd with the stock 2" blocks. But you should always use new u bolts. Also the HD springs sit about 1.5" higher than the stock springs so think about that. But front bolt and hanger bolt are 2 different sizes but both springs use the same size
I just did this about a month ago. One thing I found was dont mess around and try to do it without dropping the tank, just lower it and be done with it. I wasted 3 hours trying to get around it, dropped it and it maybe took 15 minutes.
I found a 2500 from the self pull yard by me and picked up a set for 15.00 a side. Yes one five dollars. The truck is night and day difference, the way is should have came from GM. I used the same bolts in mine.
