Spurshot Posted April 22, 2015 Share Posted April 22, 2015 Like a deeper wheel, spacers put more leverage on the suspension. It may actually ride better. Link to comment Share on other sites More sharing options...
Jake56 Posted April 22, 2015 Share Posted April 22, 2015 The physics of spacers and claiming they make no difference seems suspect. If spacers are moving the attachment to the axle out from where it was then it would seem that hung weight is further out from the bearing. I have somelimited experience with wheel spacers, in that I purchased two inch spacers for my Kubota tractor (fancy aluminum billets made) for my rear axle, to make the tractor more wide stance on hills. It works, but I knew I would be voiding my warranty on axle and bearing problems with my tractor. What is different about spacers on a pickup truck? Maybe I am missing something ? Link to comment Share on other sites More sharing options...
Hult Posted April 22, 2015 Author Share Posted April 22, 2015 The physics of spacers and claiming they make no difference seems suspect. If spacers are moving the attachment to the axle out from where it was then it would seem that hung weight is further out from the bearing. I have somelimited experience with wheel spacers, in that I purchased two inch spacers for my Kubota tractor (fancy aluminum billets made) for my rear axle, to make the tractor more wide stance on hills. It works, but I knew I would be voiding my warranty on axle and bearing problems with my tractor. What is different about spacers on a pickup truck? Maybe I am missing something ? Voided your warranty? This the same with trucks? Link to comment Share on other sites More sharing options...
Truckerado Posted April 23, 2015 Share Posted April 23, 2015 Add me as another user with all kinds of hub centric spacers & adapters, back in my road course days we used them all the time, with proper fitment & torque specs there were never any issues. Link to comment Share on other sites More sharing options...
lockey14s Posted April 23, 2015 Share Posted April 23, 2015 I measured my studs the other day when i had the wheel off because i would like to add wheel spacers eventually. its about 1.6" but the end of it is a tapered end and smothed off so there are no threads to engage. you actually have about 1.5" of thread to begin with, which I would like to go with a 1.5" spacer. wheel spacers shouldnt put any more stress on the hub than an aftermarket wheel with more offset would. Link to comment Share on other sites More sharing options...
WendysOrBust Posted April 23, 2015 Share Posted April 23, 2015 Like Spurshot said above, adding wheel spacers, depending on size, will decrease overall spring rate thus making a softer ride. A 1" spacer will not make much of a difference though. Link to comment Share on other sites More sharing options...
Jake56 Posted April 24, 2015 Share Posted April 24, 2015 So it seems to be obvious then that despite what the sellers of truck wheels and spacers would tell us.........that anything that moves the weight pivot attachment point further from the bearings is going to cause increased loads and wear on the truck bearing pieces. So although the truck bearing might be robust enough , they are seeing increased loads that will eventually cause wear or fractures depending on severity of loads imposed. I imagine that is why various tractor manufacturers void warrany claims where spacers involved. Link to comment Share on other sites More sharing options...
JerryCanada Posted April 25, 2015 Share Posted April 25, 2015 Have had 1.5" spacers installed on a '04 Dodge before. When driving on roads with deeper ruts it always kept on pulling one side or the other because the wheels weren't the same width as them. Also you will feel more the holes and imperfections of the road in your steering. Link to comment Share on other sites More sharing options...
ccdies Posted April 26, 2015 Share Posted April 26, 2015 I put 2" adaptors on my truck, my wheels are 20X12 with a 44 offset, so far no problems, and looks awesome to me Link to comment Share on other sites More sharing options...
Stoddard Posted April 27, 2015 Share Posted April 27, 2015 Like Spurshot said above, adding wheel spacers, depending on size, will decrease overall spring rate thus making a softer ride. A 1" spacer will not make much of a difference though. So what you are saying is if you effectively spaced your wheels 4" + out, it will lower the truck? This is incorrect. The only thing that affects spring rate is the suspension geometry and the springs themselves. Link to comment Share on other sites More sharing options...
Rawyzf Posted July 10, 2015 Share Posted July 10, 2015 Bringing this back to life. Does anyone have pics of OE wheels with spacers? If so, please post them up with details on width of spacer. Link to comment Share on other sites More sharing options...
EChavez Posted July 11, 2015 Share Posted July 11, 2015 Bringing this back to life. Does anyone have pics of OE wheels with spacers? If so, please post them up with details on width of spacer. I'll get one for you as soon as I get new tires. I just can't decide on 275/60 or 305/50. Want to keep the tires P rated. But, here's a truck with OE wheels/tires on 2" RC spacers. Link to comment Share on other sites More sharing options...
Rawyzf Posted July 11, 2015 Share Posted July 11, 2015 I'll get one for you as soon as I get new tires. I just can't decide on 275/60 or 305/50. Want to keep the tires P rated. But, here's a truck with OE wheels/tires on 2" RC spacers. Thanks! From that angle, looks like 2" is a bit more than I want. Would love to see 1.5" spacer [emoji4] Sent from Tapatalk App - Samsung S6 Link to comment Share on other sites More sharing options...
EChavez Posted July 11, 2015 Share Posted July 11, 2015 Thanks! From that angle, looks like 2" is a bit more than I want. Would love to see 1.5" spacer [emoji4] Sent from Tapatalk App - Samsung S6 Ask and you shall receive. Before After Link to comment Share on other sites More sharing options...
Rawyzf Posted July 11, 2015 Share Posted July 11, 2015 Ask and you shall receive. Before After Grrr, I think 1" would be perfect. Don't get me wrong, your truck looks great, but that might be a tad much and do some chipping to the sides. Your back looks great, but the fronts seem to poke out a tad more. Or maybe it's just the angles. Sent from Tapatalk App - Samsung S6 Link to comment Share on other sites More sharing options...
