Wiper fluid keeps freezing
Why does my wiper fluid keep freezing? Its rated for -25 and has only gotten down to 5 degrees. Last year we had days -25 and it never froze so why now? I hit the squirter and nothing comes out its totally full but frozen like an ice block
  • Replies 35
Either blended with summer diluting the alcohol so it was still able to freeze or maybe just a bad batch. On a warm day drain it refill with winter stuff and run the heck out of the pump to get the winter stuff into the lines. Hopefully the pump is OK.
Happened to my Z some weeks ago. The reservoir had summer formula, but it wasn't full so I poured in the winter formula and the next day, windshield washer worked again; pumpis fine.
Try a Hair dryer / Heat gun . that way you can point it at the tank and wriper lines . when it get's unfrozen ,drain/pump it empty, then put New stuff in. Good Luck
What I'm wondering is that the fluid should stay liquid down to -20F, but now it's frozen solid. What was the mistake? Manufacturer labeled it wrong? Did someone read the writing wrong (supposed to be 20F or +20F)? Was it somehow diluted with straight water in the reservoir?
