ChevyRoofer Posted September 6, 2016 Share Posted September 6, 2016 Prices of these? Only from the dealer? Quote Link to comment Share on other sites More sharing options...
NIXONRIDE Posted September 7, 2016 Share Posted September 7, 2016 Well thanks to the write up and TXTrucks I got mine wired up today...definitely a classy mod that IMHO upper models should have from the factory. Quote Link to comment Share on other sites More sharing options...
jakewake23 Posted September 7, 2016 Share Posted September 7, 2016 Has anybody seen any that say high country? i feel like ive seen a set of them somewhere but haven't been able to find them, id really be interested in a set of them if i could find some that said high country! Quote Link to comment Share on other sites More sharing options...
NIXONRIDE Posted September 7, 2016 Share Posted September 7, 2016 Prices of these? Only from the dealer? I got mine off eBay and they where $250 for the set. Quote Link to comment Share on other sites More sharing options...
EChavez Posted November 13, 2016 Author Share Posted November 13, 2016 Would anyone that installed these happen to know which wire on the wiring harness would go directly to power? I want to wire these into my step lights and not into the dome lights. Quote Link to comment Share on other sites More sharing options...
pgamboa Posted August 15, 2017 Share Posted August 15, 2017 (edited) Just completed this install thanks to this thread. Since there wasn't anything I could find on the install, I made a "How-To" video on it. Enjoy! https://youtu.be/6vFuV9TAGZE Edited August 21, 2017 by pgamboa 6 Quote Link to comment Share on other sites More sharing options...
WhiteDiamond210 Posted August 15, 2017 Share Posted August 15, 2017 (edited) I would like to verify before purchasing that these will fit a 2014 Silverado Crew Cab? Is GM 22933515 the correct part number for cocoa dune interior? Thanks in advance! Edited August 15, 2017 by Whitediamond210 1 Quote Link to comment Share on other sites More sharing options...
Rock1500 Posted August 15, 2017 Share Posted August 15, 2017 Do they make these saying gmc or Sierra? Sent from my Pixel XL using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
pgamboa Posted August 16, 2017 Share Posted August 16, 2017 Do they make these saying gmc or Sierra? Sent from my Pixel XL using Tapatalk Yes they do. Here is an eBay link for GMC. https://www.ebay.com/itm/222555056551 Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
pgamboa Posted August 16, 2017 Share Posted August 16, 2017 (edited) I would like to verify before purchasing that these will fit a 2014 Silverado Crew Cab? Is GM 22933515 the correct part number for cocoa dune interior? Thanks in advance!Should be a direct fit as 2014 trucks are built the same (from my observation). Part #s obtained from Chevy/GMC website. Sent from my iPhone using Tapatalk Edited August 16, 2017 by pgamboa Quote Link to comment Share on other sites More sharing options...
pgamboa Posted August 16, 2017 Share Posted August 16, 2017 Chevy Black - Part # 22933513 Chevy Dune - Part # 22933514 Chevy Cocoa - Part # 22933515 GMC - Black - Part # 22933517 GMC - Dune - Part # 22933518 GMC - Cocoa - Part # 22933519 GMC - Shale - Part # 23450584 Sent from my iPhone using Tapatalk 4 Quote Link to comment Share on other sites More sharing options...
Bomber55 Posted August 19, 2017 Share Posted August 19, 2017 Got them installed last night. They fit perfectly. Wiring was easy except for the fact that they don't come with instructions. But I downloaded instructions from GM. Have done them before but couldn't remember connector and pin numbers. The wiring was exactly the same as Tahoe/Suburban as described in the instructions. I don't understand why they don't offer them for the pickups. All you need is power and ground. I used a ground on the left "A" pillar and connected the power wire to connector 7 (gray) pin 1 (gray wire) of the BCM and they come on with the dome lamps.They look awesome but I can't get a good picture that really shows the blue color. I think I took about 50-60 pic's but never got a good one. That is awesome!! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bomber55 Posted August 19, 2017 Share Posted August 19, 2017 So I finally got around to installing the new plates. Definitely a cool addition, although they are a bit pricey, I think they are worth the dough. If any one is interested, I took a few photos along the way. This little tool helps to remove the panels and minimize damage. The old sill pops off pretty easily, you could also remove it by hand, gently... use care as the backside edges can be sharp. The upper part of the sill pops away from the A-pillar toward the rear of the cab. It is easier to remove the panel under the steering column to gain access. It is held in place by two #30 Torx screws here And here. The panel then pops off toward the rear of the cab. Use gentle force... it will pop right off. The BCM is visible right above the E-brake pedal. the connector of concern is the left connector, gray in color. Unplug and remove the connector. The terminal lock bar will have to be released to remove the terminal. Just use a small dull screwdriver to gently lift the lock bar. It wont come off, but will lift up about 1/8 inch. This is the wire of concern that will be used, it is gray in color. The terminal is held in place by a small locking tab, which must be released from the female side. (shown). once released the wire is pulled from the other side. You're supposed to cut this terminal off and use the supplied butt connector to attach this to the sill plate harness. I opted to install a male connector to the sill plate harness and connect the two that way. Plug the sill plate harness wire, with the female connector, into the BCM connector, close the lock bar and reinstall the connector to the BCM. You can see in the photo, my connector for the sill plate harness. This would be the butt connector which comes attached. Route the sill plate harness carefully under the steering column. I zip tied it to the support bar to keep it from tangling with control pedals, shift linkage, etc. Across the center console, behind the audio/climate controls... To the passenger side behind the glovebox. Route carefully to the passenger A-pillar and zip tie in place, leaving enough slack to facilitate plugging and unplugging. I let it hang about to the floor. Route the short side on the driver side, behind the E-brake pedal and zip tie to existing harness, leaving enough slack on this side as well. Plug the new harness into the sill plate and press the red lock tab forward. The ground wire on the sill plate harness must be attached to any clean metal stud. I used the mounting stud for the steering column support. Now reassemble all the removed parts. If all went well, the sill should illuminate when any door is opened, in the same manner as the dome light. I found the sill is a little bright for my taste... I plan to experiment to reduce the temperature of them. From a distance though they really make a nice addition. Nice write up! Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
SkippyG4 Posted August 20, 2017 Share Posted August 20, 2017 Wish there was a z71 set. 5 Quote Link to comment Share on other sites More sharing options...
sk Posted August 21, 2017 Share Posted August 21, 2017 Just completed this install thanks to this thread. Since there wasn't anything I could find on the install, I made a "How-To" video on it. Enjoy! https://youtu.be/XGDRpmNOKNI Hey Phil - the video doesn't show up for me. 1 Quote Link to comment Share on other sites More sharing options...
