Pump won't stay on during fuel ups
Had a similar issue with mine, ended up being the fuel fill tube. there's a plastic insert in the hose and on mine it looked almost swollen and wasn't allowing enough flow. Replaced the fill tube and it works great now. The tube is very easy to get at, I would pull it out and straighten it out to have a look down the tube and see if it looks open or restricted.
GM uses an electronic solenoid in its fuel tank that allows air to escape. It's an electronic part that needs to be replaced. Yours is probably under warranty.
How many years have they done this?
  • 4 years later...
I had the solenoid and the evap canister replaced in my ‘18 after I couldn’t fill the tank past 3/4 a tank along with the pump stopping every 10 seconds. One dealer said it was normal and another dealer said there was an issue, diagnosed it and fixed it.
