spoolindawg Posted August 30, 2017 Share Posted August 30, 2017 Here's my ltz, this trucks gotten me through the flooded streets of Dickinson over the last few days. Pulled a few cars out of the road and cleared a fallen tree that had a road blocked. Have the 5100s on highest setting. Tire size is 275/60r20. Going to add the rear 5100s soon and possibly some 1 inch blocks. 1 Quote Link to comment Share on other sites More sharing options...
RHStansbury Posted August 30, 2017 Share Posted August 30, 2017 Just got an email back from Bilstein saying the 6112s will net 1.85" of lift. Folks are getting more than that from 5100s, right? Quote Link to comment Share on other sites More sharing options...
spoolindawg Posted August 31, 2017 Share Posted August 31, 2017 I never measured mine but from what I gathered most are getting 2 inches out of the 5100s. My truck seems to have settled a little, it looked higher at first. I have put about 200 miles on the truck so far. Quote Link to comment Share on other sites More sharing options...
gone_fishing Posted September 1, 2017 Share Posted September 1, 2017 I never measured mine but from what I gathered most are getting 2 inches out of the 5100s. My truck seems to have settled a little, it looked higher at first. I have put about 200 miles on the truck so far. Thank you for posting that pic. I plan on installing 5100's up front soon along with the same size tires you have. Just to confirm, when this pic was taken you didn't have any additional lift in the rear correct? Also if you have a chance could you take some measurements? Truck looks pretty level in this pic but I'm curious if there is any rake. A few more pics would be great if possible (now I'm getting greedy ) Thanks! Quote Link to comment Share on other sites More sharing options...
spoolindawg Posted September 1, 2017 Share Posted September 1, 2017 0 lift in the rear in the pic. I can measure and post results, where do you measure from? Ground to wheel well correct? Quote Link to comment Share on other sites More sharing options...
gone_fishing Posted September 2, 2017 Share Posted September 2, 2017 0 lift in the rear in the pic. I can measure and post results, where do you measure from? Ground to wheel well correct? Thanks. Yes ground to wheel well lip (center of tire). Curious to see how the front compares with the rear. 1 Quote Link to comment Share on other sites More sharing options...
spoolindawg Posted September 3, 2017 Share Posted September 3, 2017 Thanks. Yes ground to wheel well lip (center of tire). Curious to see how the front compares with the rear. Just under 40 1/8 inches in the rear 39 even in the front. Been pulling a trailer and a loaded bed all weekend and it wasn't sqauting to bad at all. Quote Link to comment Share on other sites More sharing options...
Kyleorsini Posted September 4, 2017 Share Posted September 4, 2017 Do we have a release date on the 6112s looking to order from new suspension in the next couple months Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gone_fishing Posted September 5, 2017 Share Posted September 5, 2017 Just under 40 1/8 inches in the rear 39 even in the front. Been pulling a trailer and a loaded bed all weekend and it wasn't sqauting to bad at all. Thank you! Quote Link to comment Share on other sites More sharing options...
Eddie 70 Posted September 5, 2017 Share Posted September 5, 2017 Ordered my Bilsteins on Friday. They should be here in the next week or so. I can handle the rears easy enough. If I remove the struts, any idea what the going rate on getting the shocks removed and replaced? An alignment will follow replacement. Quote Link to comment Share on other sites More sharing options...
Bwoodkid Posted September 6, 2017 Share Posted September 6, 2017 Ordered my Bilsteins on Friday. They should be here in the next week or so. I can handle the rears easy enough. If I remove the struts, any idea what the going rate on getting the shocks removed and replaced? An alignment will follow replacement. Local shop here is CA quoted me $50 / strut. Big O tires will do it, if you have that shop around. 1 Quote Link to comment Share on other sites More sharing options...
Eddie 70 Posted September 6, 2017 Share Posted September 6, 2017 Local shop here is CA quoted me $50 / strut. Big O tires will do it, if you have that shop around. Thanks for the reply. That gets me a ball park number so I am not too terribly shocked when I go in. Quote Link to comment Share on other sites More sharing options...
jbh4381 Posted September 6, 2017 Share Posted September 6, 2017 (edited) Ordered my Bilsteins on Friday. They should be here in the next week or so. I can handle the rears easy enough. If I remove the struts, any idea what the going rate on getting the shocks removed and replaced? An alignment will follow replacement. I had mine done by a shop. They quoted me 1.5 hours of labor. With the alignment and 7% tax, I was at $266 OTD. Edited September 6, 2017 by jbh4381 1 Quote Link to comment Share on other sites More sharing options...
michigan2500hd Posted September 6, 2017 Share Posted September 6, 2017 Local shop here is CA quoted me $50 / strut. Big O tires will do it, if you have that shop around.I paid about $190 for installation. Send the average around here. The place that did it was considered the best in the area pls that cost included alignment. Sent from my E6810 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Eddie 70 Posted September 6, 2017 Share Posted September 6, 2017 I had mine done by a shop. They quoted me 1.5 hours of labor. With the alignment and 7% tax, I was at $266 OTD. I paid about $190 for installation. Send the average around here. The place that did it was considered the best in the area pls that cost included alignment. Sent from my E6810 using Tapatalk Is this with them removing the struts or did you remove the struts? Quote Link to comment Share on other sites More sharing options...
