Bilstein shocks thread
Super fast shipping, great prices. Thank you ! Highly recommend MRT.
They came in already...looking forward to installing them when I have some free time. Going to PM you on some wheel prices here in a little bit.
Thank you sir! If weve got an item in stock, we try to get it to you within 72 hours! We are greatful for your business!
If anyone else is looking, our pricing in unmatched and our inventory levels are pretty good right now for fast turnaround.
07+ GM / Chevy 1500 2wd / 4wd Bilstein 5100 Complete Set - http://shop.mrtmotorsports.net/bilstein-shock-sets/bilstein-5100-complete-set/2423830433238319/i-2304103.aspx
Have they came out with 5100's for the new Colorados?
Yes! Weve got the kit here - 2015+ GMC Canyon / Chevy Colorado Bilstein 5100 Complete Set - http://shop.mrtmotorsports.net/bilstein-shock-sets/bilstein-5100-complete-set/2425315424265874/i-2501887.aspx
Are there better coil springs, maybe an eibach spring to go along with these to increase ride quality?
Same thing I asked. After some research I found out that the factory coils are 550 lbs./in. spring rate. So it's a matter of coil length and spring rate. I should just call Eibach and ask.
Edit: Many of the popular coilovers use (up to 3 inches of lift) an Eibach Coil-Over Spring, 3.0 in. Inside Diameter, 14 in. Length, 700 lbs./in.Spring Rate. They cost around $100 each.
I happen to have a spare set of factory coils, so I'm going to measure them this morning. So our factory springs measure around 12 in. length wise. That's why RHA struts support up to a 2 inch lift without a problem. I'm going to add a video that helps explain it all.
Edited by Severado
The valving in the shocks is designed to work with the factory coil spring, upping the spring rate may cause a worse ride then factory. If you havent tried the 5100 shocks on their own with the factory springs first, you might be getting ahead of yourself a little. Almost all aftermarket springs will be a heavier spring rate, which may not be what you are looking for. We normally bump the spring rate by 50lbs for every 150lbs of added weight over the front. We can supply "universal" coil springs that will fit these shocks no problem, but we would need to know the requested spring rate and length.
The third ring on the 5100s was just a smidge lower than the 4600s + 1.5 level. That level kit left me perfectly level looking. I did not like it. I still wanted a slight rake since I tow and the third ring left it just like I wanted. I cant imagine doing a 2" without adding the rear spacer. It would look nose high.
I never ran the 4600s without level. I did both (and new tires) all at the same time. THat made it really hard to diagnose the issue. I think it was the level kit though if I had to put money on it.
Edited by Texas_GMC_Z71
Excellent review. We suspect is was the spacer, as the leveling spacers limit the already limited travel these trucks have from the factory. The 5100 is a superior shock to the 4600 in ride quality as well.
I've got the 5100's front and rear, front's set to 3 as well. The front shocks perform well- very well behaved. The 5100 rear shocks are a little jarring though. Much more so than the Bilstein 5160 rear shocks I had on a 2016 Tacoma. I was kind of surprised.
Thank you for the continued orders!!
We are stocked up on 5100s, get yours here - http://shop.mrtmotorsports.net/bilstein-shock-sets/bilstein-5100-complete-set/2423830433238319/i-2304103.aspx
Do you have the NHT Heavy Tow package?
Yellow/Blue = 4600
Silver/Black = 5100
Both a big upgrade over the stock shocks. Go with the 4600 if you want to keep stock height or are needing maximum control for towing or want to run a leveling spacer. Go with the 5100 if you want to level the truck without a spacer or if you like to go offroad.
    247.6k
    2.6m
    Liftedrado2021
    Liftedrado2021
  • Who's Online   1 Member, 0 Anonymous, 831 Guests (See full list)
