1/4 mile times
Temple Academy Dragway (Little River)
03-15-03 Test-n-Tune night
weight (at track scale) = 6,550 lbs
Best time:
reaction = 0.9194
60 ft = 2.2417
330 ft = 6.4735
1/8 ET = 9.9603
1/8 mph = 71.54
1/4 ET = 15.4175
1/4 mph = 88.42
Temps were about 70 F.  Blower is only making 5 psi boost at redline (5,200 rpms).  Reaction time sucks.  :jester:  I seem to get off the line OK without any wheel spin, but at the 50 ft mark the blower spools up and I start smoking both back tires.  :eek:  On take off I powerbrake to 2000 rpms (at 2,300 rpms I get wheel spin on take off).  All and all, I was the largest fastest truck of the night (street legal).  :hail:  :nonod:  Somehow managed to wax a late model factory supercharged Grand Am. :nonod:
Wow!  Nice run!  88mph is moving for a 2500 with that slab of armor you have on the front of it!  A 2.24 60' is great too!
I've got a friend with a 98' convertible GT mustang with a 5speed that only runs 15.1's at 91mph in good air.  His car probably weighs half what yours does, and it only runs a hair faster.  :flag:
:flag:
Alright just got back from Temple track. Made 12 runs pretty much back to back.
I have a 2wd extend cab short bed, 5.3 automatic.
Replaced muffler only with Flowmaster 70 series stock pipes.
UPD intake w/ K&N.
Using a HPP3 for shift adjustments only.
Set up a wet NX system using 100 pills jetted for safety.
Bottle temp pretty low (aprox 60 deg) before first run even.
Best run was number eight..................Against a Corvette
  ME                                              CORVETTE
  Reaction.......1.0556.....................  0.7641
  60 ft............2.2409.....................  2.2445
  330 ft..........6.1009.....................  6.1017
  1/8 ET.........9.2758.....................  9.2895
  1/8 MPH.......77.63.......................  77.39
  1/4 ET.........14.3950....................  14.3219
  1/4 MPH.......93.10.......................  99.00
Some observations............................
I'm sure I was running rich on all runs due to low bottle pressure.  :smash:
I need to install my traction bars, too much tire hop off the line.
Also need some stickier tires.  :D
I need to get a bottle heater/gauge setup.
Once pressure is consistant, go to a dyno to set A/F ratio on 150 jets would be most beneficial.
Some where in all this install a torque converter.
I actually want to be in the thirteens.   :crackup:
White extended cab with black factory flares. Kinda looks like a 4x4 but its just a 2wd with a 3 inch lift.
Funny thing is the day before I was hauling a 16 foot flat bed completely loaded with furniture helping a friend move here from south of Corpus Christi. Over 300 miles each way. Now thats a do everything truck.
9.103 @74 mph 1/8 with 90hp juice @7150lbs.......1.81...60 ft time with a 4wd high launch.....duramax /allison 2002 crewcab short bed.......at the track..........with a gtech and 125 hp hot juice.....0 to 60 5.7 seconds and 1/4 mile 14.52 @94mph @7400lbs all on No 2 diesel fuel......see you guys at a red light some day......if your down south :flag: dave
